07-10-2006, 09:42 AM | #1 |
Still Fighting this..
my 69 has an HEI all new dizzy parts from pickup, module, cap, rotor, and Accel coil. Well here in lies the problem. my truck starts and runs down the road fine, until you get into it. WOT it dies, TACH goes to ZERO. Its almost like it loses power to the dizzy. So first I thought, when the Vaccum adv open it causes a ground. So remove the vaccum line and try, same thing. I can move the hot wire at the coil back and forth, and it will die out the same way. Ok I thought first it was the wire. So I made a new 12AWG wire from the battery directly to the dizzy. Same results. HMMMM. Ok it has to be the coil (3months old) so I take it back a get a new one. put it on and exact same thing. Now I have no idea what to do.
Could it be grounding issue? Or crossfiring inside the dizzy? What should I look for?
2006 Titan SE Crew Cab Daily Driver 2005 Mazda Tribute (Wifes car) 1969 C10 SWB 350/3 Fleet "Max" 1969 Chevelle 2 door 350/3 |
07-10-2006, 10:17 AM | #2 |
Re: Still Fighting this..
What transmission do you have?
07-10-2006, 10:26 AM | #3 |
Chance
What size engine do you have?
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 |
07-10-2006, 11:16 AM | #4 |
350/3speed
07-10-2006, 11:35 AM | #5 |
with suspected electrical problems the first thing i do is disconnect and clean the grounds and reassemble them includeing the battery terminal connections dielectric grease is your friend
07-10-2006, 12:13 PM | #6 |
Check the wire going to the pole piece in the distributer. I had a simular problem and the wire was broke. I t make a connection until you gave it the gas.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
07-10-2006, 03:52 PM | #7 |
found problem at lunch..the pickup wire had cracks in it. when the engine revved it would spark across.
Mucho Thanks
