07-19-2006, 12:12 AM | #1 |
brake lights switch
okay many read me tread on the pwoer brakes my new question is how do you adjust the brake switch wheres it at ( i know somewhere around the pedel) and how to get to it with the power brakes my pedel does not return all the way keeping the lights on so i need to know hoe to adjust the switch.
thanks in advance
07-19-2006, 12:42 AM | #2 |
Re: brake lights switch
Location--up at the top of pedal
adjust--remove wires--loosen nut on back side of switch and turn switch until white plunger touches brake pedal and pushes all the way in--connect wires and see if brakes light is off--check to see if they come on when pedal is moved--if ok turn nut back up to bracket (there should be one on front side also--tighten it against bracket.--done
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
07-19-2006, 07:41 AM | #3 |
cool thanks
07-19-2006, 09:38 AM | #4 |
Chance
Always good to have brake lights.
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 |
