Old 07-20-2006, 09:28 AM   #1
Lemield
Lemield's Avatar
Window installation/rope size?
I found the FAQ's on window installation (front or rear) for our trucks but there is not much information about the size of rope/cord that people use to put them in. Does anyone have any recommendations?
Thank you in advance.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 07-20-2006, 11:09 AM   #2
Shock_Me
Shock_Me's Avatar
Re: Window installation/rope size?
The glass shop I went to used a cord about the same size as a lawn mower start cord.
Hope this helps.
Pete
Shock_Me is offline   Reply With Quote
Old 07-20-2006, 11:43 AM   #3
boilrman
70 Chevy 3/4t
I used a string about the size you use for making a line, say for setting fence posts.
Find a job you love and you'll never have to work a day in your life.
1998 Yamaha V-Star 650
1970 Chevy 3/4t, I6 (rebuilt), 4 speed
Kokomo,IN
boilrman is offline   Reply With Quote
Old 07-20-2006, 01:46 PM   #4
incoma
incoma's Avatar
The entire point of the string is to manipulate the rubber around the channel. You won't want something too big that it doesn't easily move, and you don't want something so small that it rips or tears the rubber. I used string for fence posts like boilrman. It worked well on the front window, but tore the gasket on the back window. Perhaps I got too rough with it..?? Good luck, it's not the easiest of projects. Having someone help you is key also.
"Green Monster" (Red Sox fan)
1970 GMC survivor, 350/200 4R, 3.42 rear gears, 2.5/4 drop, ECE disc brake conversion, powder coated suspension
incoma is offline   Reply With Quote
Old 07-20-2006, 01:57 PM   #5
Lemield
Lemield's Avatar
I know all about tearing the gasket.... I tore the crap out of the one that is on there now. I used some parachute cord....not a good choice!
Thanks to all for your feedback!
Larry
Old 07-20-2006, 04:32 PM   #6
BigMike
BigMike's Avatar
Try a weedeater line. It is a plastic material and does not grab the rubber like rope or nylon does, slides real well when you lube the gasket with windex, dish soap or whatever. I have tried them all from twine to rope and have had the best performance with no grabbing or tearing with weedeater line.
Mike
BigMike is offline   Reply With Quote
Old 07-21-2006, 09:48 AM   #7
Lemield
Lemield's Avatar
Mike
Thanks Mike....I'll try it!
Larry
Old 07-20-2006, 10:25 PM   #8
incoma
incoma's Avatar
weedeater line is an awesome idea.
Old 07-21-2006, 11:16 AM   #9
ChevyDude
Larry if it takes another set of hands to help....let me know and I'm there!
ChevyDude is offline   Reply With Quote
Old 07-21-2006, 11:20 AM   #10
Lemield
Lemield's Avatar
Thanks Alex...you da man! I'll let you know....I'm still waiting for the new window seal to arrive. What an exercise in futility! I am going to put the original sliding window from the red truck BACK into the red truck.
Larry
Old 07-21-2006, 11:23 AM   #11
ChevyDude
Did ya get into the window moving biz??? LOL!!!
Old 07-21-2006, 11:33 AM   #12
Lemield
Lemield's Avatar
More like the window seal ripping business! It looks like right now!
I'm gonna try the weedeater line as suggested....sounds like it will work good since it will slide easier.
Larry
Old 07-24-2006, 09:30 AM   #13
Lemield
Lemield's Avatar
Well...I got it installed. It was tough. I decided to use some sash cord and it worked OK. Was going to use the weedeater line but only had the stuff with the sharp edges....I never would have gotten the window in without the my wife's help...she is a good helper!!!
Larry
Old 07-24-2006, 11:02 AM   #14
ChevyDude
Good deal Larry!
Old 07-24-2006, 11:07 AM   #15
Jwill41
Jwill41's Avatar
We used venetian blind cord and it worked well.
On a side note, does the rear slider window use the same seal as stock glass? I will be painting mine soon and will need new rubber.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 07-24-2006, 01:26 PM   #16
Lemield
Lemield's Avatar
As far as I know, the stock gasket fits the slider and the regular glass.
Larry
