Old 07-26-2006, 06:51 PM   #1
Jesse72
Jesse72's Avatar
Where can i find hubs
Does anyone know where I can find the front hubs for my 72 1/2 ton 4x4 w/ disc brakes, the part that bolts to the rotor not the locking mechanism inside it? I have looked all over new or used is ok.I tride a set from an 86 and the inner race on the inner bearing was to large. Any help
Thanks,Jesse
Jesse
72 4x4 Sold
59 GMC air ride ls swap
Jesse72 is offline   Reply With Quote
Old 07-27-2006, 09:38 AM   #2
Yukon Jack
Yukon Jack's Avatar
Re: Where can i find hubs
The show up on the parts board used occassionally.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-27-2006, 10:02 AM   #3
kwmech
The wheel hub--correct? the inner bearing should be lm603049 and the outer lm501349. I may have a couple of them. I'll take a look this afternoon
Old 07-27-2006, 07:57 PM   #4
nu2-72
Teeitup had lots of parts recently. Check with Randy.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 08-17-2006, 04:57 PM   #5
jamie72
jamie72's Avatar
i told you i had a set...
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 08-17-2006, 06:36 PM   #6
Blazer1970
Blazer1970's Avatar
You should be able to buy the hub/rotor assembly already together with wheel studs from most any parts store.
Blazer1970 is offline   Reply With Quote
