Hellasick
![]() Join Date: Jul 2006
Regarding the "easy disk brake swap " thread
http://67-72chevytrucks.com/vboard/s...ad.php?t=35042
Just why won't the '88-'94(?) 6-bolt rotors work with the '73 to '87 spindles. I ask cause I stripped a '85 frame for the brakes. Are the rotors too different to fit the spindle or what? Would just prefer off the shelf parts to special ones. At this point it isn't worth the extra $$ to change now. Just wish I had found this a couple years ago ![]() |
#2 | |
Active Member
Re: Regarding the "easy disk brake swap " thread
Hellasick
That is the thread I am referencing, used 88 3/4 ton spindles, etc. But either missed the difference or no one said just why these rotors, that use the same bearings would not work on the 73-87 1/2 ton spindles.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
#4 | |
Active Member
Hellasick
Not a problem. Given the way the big 3 do things, the distance between the bearings could be different. Since the back-spacing is it different , is it too much to work with the stated 1/2 ton spindles and calipers? I think everyone here knows that just because there is a slight difference, doesn't mean it can't work.
#6 | |
Active Member
Hellasick
I think that is what I'm gonna do. At cpp they are $65 each ($129 pair), which isn't that much more than these 3/4 ones. Especially if you figure the cost to modify the setup. Just like it isn't worth it to get the 3/4 ton setup with money already in the parts I have. Yeah, shipping is more. I just would have liked to buy off-the-shelf.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys Last edited by 70C10Toejam; 07-30-2006 at 12:37 PM. |
#8 | |
Active Member
