07-28-2006, 07:37 PM | #1 |
Original Manuals F/S
'69 Chassis Service Manual, some shop wear, no torn pages or marks.
'71 Chassis Overhaul Manual, some shop wear, no torn pages or marks. $20 shipped each.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks Last edited by Ironhorse; 11-05-2006 at 06:23 PM. |
07-28-2006, 07:39 PM | #2 |
Re: Original Manuals F/S
'69 Manual
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks Last edited by Ironhorse; 11-05-2006 at 06:28 PM. |
07-29-2006, 01:32 PM | #3 |
What does it all explain how to rebuild, is it just the chassis as in the suspension or is there more?
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
07-29-2006, 05:15 PM | #4 |
For the '69 manual the index covers:
Gen. info and lube, heater and a/c, body, frame, front suspension/4wd, rear suspension and driveline, brakes, engine, engine cooling, fuel system, clutch and trans., fuel tank and exhaust, steering, wheels and tires, chassis sheet metal, electrical-body and chassis, radiator and grille, bumpers, accessories, and specs. Book is nearly an inch thick. Not sure if the pic helps or not, not a camera expert.
07-29-2006, 05:20 PM | #5 |
For the '71 manual:
A/C compressor, 4-wd front axle differential, rear axle differential carrier, power brake cylinder, engine, carburetors, starting motor solenoid and decotron, trans. and clutch/ 4wd transfer case, steering gear, power steering pump and control valve, specifications. Book is nearly 3/4" thick. Pic may help.
