08-09-2006, 08:59 PM | #1 |
surprising how fast plugs burn up !!!!
i have had my 350 engine in my 69 o maybe 2 1/2 years or 5000 miles tops...
I went to murrys auto to buy plugs,, Handed the boy a r45ts A/C plug and said i want 8 of these..He said this plug..yea...He goes and does his thing, and say's i can take you on # 3 .... great i am thinking..he rings me up and said thats 2.19 cents cool out the door i go.. So i got a GREAT DEAL ON A/C PLUGS... I was very surprised at how nasty my my plugs were.. I have went thru 3 carbs and two intakes in that time.. I do have the 50,000 volt hei..? O yea and one hei module.. guess it's taken it's toll on the old plugs. you can see the base is not even rusted.. I did get them all installed without breaking any plugs I will drive it tommarrow and see if theres any difference. Last edited by rage'nrat638; 07-12-2007 at 07:02 AM. |
08-09-2006, 10:01 PM | #2 |
"Trucks with Class"
Re: surprising how fast plugs burn up !!!!
Looks like quite a bit of deposits on those. Something/oil may be getting past the rings or seals. They are not burning away.
08-09-2006, 10:29 PM | #3 |
The LuvShack Garage
Yikes, those things look toasted
08-10-2006, 06:40 AM | #4 |
I used anti-foulers on two plugs when I got to Santa Fe in my`71 camper.It had two fouled and I knew I was in higher elevation.I had tuned the truck before leaving and set timing/tach/dwell to specs.We drove north to the NM/CO border and it was running rough again.I pulled the plugs and the two w/anti-foulers were melted away/no tip!I`m 2,500 miles from home in the south Rockies with motor problems.I chucked the anti-foulers,put two plugs in,ear-tuned the truck,and finished the trip.Even dropping down into Texas and all the way back east the truck ran fine.I never needed to reset a thing.
Wierd things can happen Those old plugs are the result of your other carb problems.Fixing them doesn`t always mean,"it`ll burn off".
08-10-2006, 11:10 AM | #5 |
Oil fouling creates hard black deposits. The carburetor that’s too lean will create white deposits and/or deterioration of the insulator and poor driveability. It doesn’t matter if you have a hot HEI ignition or a stock ignition, it won’t have any effect on deterioration of the electrodes. I’m betting what you have is moisture that’s causing these deposits.
08-10-2006, 11:39 AM | #6 |
ouch!
08-11-2006, 10:06 PM | #7 |
well todays drive to and from work, was filled with extra power.
after the plug change i am betting to fuel mileage will go up a tad.. momma already say's my 69 get's better mileage than the 4.3 s-10 4x4 she drives...seems like theres always something to do on these babys when you drive them every day. Last edited by rage'nrat638; 08-11-2006 at 10:07 PM. |
08-12-2006, 12:03 AM | #8 |
Sleep-Deprived
That seems pretty cheap for 8 plugs? I don't remember what I paid last time, but it seems like they run between 1 or 2 bucks per plug.
Sounds like you got your money out of the last set.
1971 K/10 Long Fleetside 350/350 - 6" Lift 1969 C/10 SWB 292 - Sold It |
08-12-2006, 01:13 PM | #9 |
$2.19??? You got a 1969 price on those AC spark plugs! Must have been a new kid at the counter and surely his cash drawer came up short that day!
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
