Old 08-12-2006, 02:39 PM   #1
smills78gmc
Radiator Question
What does this port do? The one under the overflow but over the tranny lines
smills78gmc is offline   Reply With Quote
Old 08-12-2006, 02:42 PM   #2
smills78gmc
Re: Radiator Question
The ports for the intake is on the other side and the one for the water pump is below the tranny lines at the bottom. It has been 8 months since I removed the radiator so my memory is foggy. Please help
Old 08-12-2006, 02:44 PM   #3
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
that's the return line from your heater core. You will have a line from the top of the intake to the heater core port on the firewall then the return goes back into the radiator port you have there. I've added a valve where the supply line to the heater core can be shut off during summer. This keeps the cab a little bit cooler. Just make sure to do the supply side from the intake and not the other side after the heater core to the radiator. This would cause the heater core to burst. Also if you install it make sure to run it open about once a month to keep it flushed out.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 08-12-2006, 04:17 PM   #4
smills78gmc
Does that mean there is no heater hose that attaches to the water pump?
Old 08-12-2006, 04:34 PM   #5
Prerunner1982
Prerunner1982's Avatar
It can go from the intake or the water pump, as long as the other port is blocked off. Mine come off the intake....
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 08-12-2006, 04:48 PM   #6
smills78gmc
Ok, I see. Thanks guys
