08-13-2006, 09:34 PM | #1 |
Air condition?
I have a 78 Chevy bonanza 1/2 ton that I cannot get the air conditioner clutch compressor to engage. I Jumped it out with a wire off the battery and it will work. Does anyone know where the fuse is located that cuts the compressor on?
It is not on the fuse block I checked all of them and they are good. Also will the compressor designed to not come on when low on freon? Maybe that is the problem. The fan motor works fine. |
08-13-2006, 10:25 PM | #2 |
Insert Witty Text Here
Re: Air condition?
Yes, there is a switch that will prevent it from coming on when the freon is low. On my '86 it is on the drier/accumulator, the only wires that go to it.
Slonaker |
08-13-2006, 11:36 PM | #3 |
Stepsides RULE
Re: Air condition?
Not to hijack your thread... but props for putting an 80 grille in your truck Nice truck overall
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
08-14-2006, 09:46 AM | #4 |
Re: Air condition?
On passenger side near firewall there is a plug that connects to a pressure switch one the AC line. Unplug it and jumper the plug with a piece of wire. It should make the compressor come on. If it does then you are low on freon.
08-14-2006, 04:41 PM | #5 |
Parts and more parts
Re: Air condition?
As said above--There is a black rubber plug connected to the aluminum accumulator on the heater housing. Unplug that and stick a jumper wire into the plug assembly, the compressor should engage the clutch. This is a sensor for a low freon charge.
08-14-2006, 10:30 PM | #6 |
Re: Air condition?
Thanks for the feedback on the air condition. I jumped out the pressure switch and the compressor came on. Now I think I will change to the new freon,since I gave my brother in law my last 3 cans of R-12 that I found in the garage at my mothers( STUPID ME live and learn)
Whats is involved with the new freon change over? Is it easy? |
