PIMPING RIDES
1981 c/10 trans
i got an 81 chevy c/10 and i am trying to figure out how to the the bell housing bolts out the easiest . do you have to let the trans mount go and let the trans hang down or what . having a hard time getting at the bolts . help please .
1964 CHEVY 1/2 C/10 FLEET ![]() 1981 CHEVY 1/2 C/10 FLEET ![]() 1995 DODGE 1500 V6 FLEET ![]() EAST http://www.flickr.com/photos/bigasspimp/?saved=1 |
Re: 1981 c/10 trans
When I've done it, I always drop the tranny mount and pull out driveshaft to let the tranny come down a bit. Be carefull that it doesn't drop too much cause the motor will also tilt back and the distributor can hit the firewall. Once its tilted down, I use an impact and a long extension, about 2-3 ft to undo the bolts. With it tilted down you should be able to access all the bolts.
Parts and more parts
Re: 1981 c/10 trans
I use a 3/8 socket and ratchet, with two long extensions and a6" extension between the socket and the ratchet. I can position myself at the rear crossmember and reach the bolts on the bell housing, with ease. I also have taken the top bolts out of the bell housing by sitting on top of the motor and reaching down past the distributor. I pulled the motor out of the truck in less than 3 hours that day.
Re: 1981 c/10 trans
last time I did this I sat on the engine and took off all that I could, the rest were accessed from below without dropping the cross member. Engine was pulled, trans left in the truck.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
needin' money
Re: 1981 c/10 trans
when i pulled mine out, i got the top 2 while i was sitting on top of the motor, and the bottom 4 i got out after i put a jack under the trans and took the crossmember out(driveshaft,tq bolts,etc) and then just dropped it down by lowering the jack
SWB Stands for Short Wide Bed |
PIMPING RIDES
Re: 1981 c/10 trans
thanks guys for all the help .kinda thought what you guys suggested . this is the best place ever .
Slots go on anything!
Re: 1981 c/10 trans
a 9/16" swivel socket will do wonders there. I use that, and as many extensions as it takes to loosen everything when you are sitting behind the crossmember. the 9/16" swivel socket will be 10 bucks well spent.
1974 Jimmy- 5.3/4L80e/NP241 |
