Happy to be here
![]() Join Date: Mar 2000
Paging Tony@AirRideTech
Tony-
I'm having trouble with the pressure gauge on my 77. When I start my truck it comes on and reads correctly. After a short period the digits fade out. I have checked the ground wire, and made sure it was making a solid connection. I also checked the +12v source and it keeps constant voltage even after the display fades out. What the heck is going on? Oh, btw it's one of these- ![]()
Junior Member
Re: Paging Tony@AirRideTech
that is strange....... It sounds like the gauge is bad or like you are loosing continuity somewhere. Do you have your "illumination" wire hooked up? I might try disonnecting that if you do and see what happens.
#3 | |
Seņor Member
Happy to be here
Tell me what colors wires go where and I can give an answer. I know Roger gave the installation guide back to me, but I can't seem to find it. I traced the harness coming from the gauge. Four wires go south and I will assume they go to the sensors. I have a black wire going to ground, and a red wire going to a fuse terminal that is keyed hot. Is there a third "illumination" wire? If so, what color is it. That could be my problem.
BTW- As a point of reference the gauge has worked fine every since it was installed. This just started happening after I picked it up from the motor install.
#5 | |
#6 | |
Happy to be here
I did just discover a yellow wire that looks like it was connected (end is stripped) and now it's not. I did not have time to trace it back and see if it was coming from the guage harness. XXL- I assume it's vacuum fluorescent lighting as it is not LED.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 08-20-2006 at 10:22 PM. |
#7 | |
Seņor Member
#8 | |
Seņor Member
Junior Member
It is VFD... they were built for us by Dakota Digital. Give someone a call up at Dakota and see what they have to say.... the blue wire is for your illumination dimmer. Unhook that one if it is not already done and see what it does.
