04-16-2002, 08:08 PM | #1 |
Ash Tray
Am I correct in assuming that the ash tray was removable in all the years? I got a 72 cab and can't get it out, and there are not any screws holding it in. Also is it the same as a 68 ash tray? Thanks
------------------ http://www.geocities.com/a68rod
Build Thread |
04-16-2002, 08:17 PM | #2 |
Old member
Push down on the center tab in the ash tray and it will come out in less someone has done something to it before you. As far as them all being the same I don't know. Someone else will have to answer that one.
------------------ Andy 71's Are for ever!!! or 67,68,69,70,72 www.geocities.com/chevy71tpi/main.html] www.picturetrail.com/Andy4639]
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
04-16-2002, 08:20 PM | #3 |
I am not talking about the ashtray itself, but the part that it slides in and out of. The part that screws to the dash and holds the ashtray in.
Build Thread |
04-16-2002, 08:36 PM | #4 |
Mine don't come out either(1967)
------------------ 67 GMC Stepside(UNDER CONSTRUCTION) 67 GMC Custom 67 Chevy C-30 |
04-16-2002, 08:55 PM | #5 |
Open the ash tray, press down on the little lever and it comes right out. My 72 slides on plastic rails while my 70 has ball bearings, but they all slide out.
------------------ 70 GMC 3/4 ton Sierra Grande 402/TH400 72 Jimmy 4WD 4spd 4" & 35's 64 Corvette Coupe 68 Camaro 'vert TPI & TH700 69 Z/28 355 12.6's @110 72 Datsun 240Z-ol' reliable
04-16-2002, 09:08 PM | #6 |
i believe he's talking about the ash tray mount. mine has two screws in it and the bottom is spot welded.
04-22-2002, 01:41 PM | #7 |
I've seen them both ways, some spot-welded, some screwed-in. Don't remember if it was a year thing or what...
1998 k1500 xcab Had: 1972 blazer4x4, 350/350, factory a/c |
04-22-2002, 05:11 PM | #8 |
its all about the +6 inches
My 2 '70's and 1 '69 were screwed in...no spot welds. I only know this becouse the first longhorn had a better assembly than either of the other 2 trucks, so it has gone from truck to truck.
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
04-22-2002, 10:05 PM | #9 |
Just had mine in and out to install a stereo, and it had two screws above the tray, and two more underneath, accessible AFTER you remove the heater controls.
------------------ Just as if I knew what I was doin'
Just as if I knew what I was doin' |
