08-31-2006, 06:46 PM | #1 |
LS1 headers that fit
After 3 sets of headers I have finally found some that fit. The only thing they are close to is the start and block. Due to such a tight fit you can only use a 2" collector (which I dont like). The headers are hooker headers block huggers for the ls1's. I believe these are as close as we are going to get using a production header.
08-31-2006, 08:33 PM | #2 |
Junior Member
Re: Found Holy Grail (LS1 headers that fit)
Blazerboy I bought the Stainless Works header for an LS1 with a Wayne Due frame and they fit nice. The only 2 small problems that I had was it put the connection to the collectors right in the middle of my cross member. I'm having 4 1/2" cut off of them to fix the problem but I'm guessing they could do this if you asked ahead of time since they fab them to order. I'm using 3" collectors and the side of the tube will also brush the crossmember support but if I'd gone with 2 1/2" I'd be fine.
I can take some pics if your interested, I haven't had them cut yet so you could see what they look like.
1972 K/5 4x4, Radixed LS1 6.0, 428HP/445TQ, Lingenfelter GT2-3 cam, WCCH 90mm J-Tube, LS2 90mm TB, Stainless Works Headers, NV4500, 4.56 gears, Detroit Lockers, 14 bolt FF, Dana 60, 4 wheel disk Hydro Brakes, dual electric fans, Autometer guages, 4" lift, Zero Rates, Weld Evo Velocity XT8 wheels, 35x12.5x17 Super Swamper SSR's..... http://s72.photobucket.com/albums/i1...tos/?start=all |
08-31-2006, 09:22 PM | #3 |
If the corvette exhaust manifolds fit, would headers for a corvette work? They'd have to clear the same area....?? Did you try those?
"Green Monster" (Red Sox fan) 1970 GMC survivor, 350/200 4R, 3.42 rear gears, 2.5/4 drop, ECE disc brake conversion, powder coated suspension |
08-31-2006, 09:27 PM | #4 |
Sanderson is supposed to be working on a set specifically made for the 67-72 trucks.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
09-01-2006, 06:05 AM | #5 |
I didnt try the corvette ones. I tried some for a truck and midified bigblock headers. The stainless works look nice but I couldnt put out that kind of money for a set. The hookers were only $195 so I figured they were worth a try. And the headers currently available from sanderson dont look like they would fit. The collector is about1-2" further back than the hookers and that would put it right on the starter.
09-01-2006, 07:19 AM | #6 | |
Rob
09-01-2006, 08:23 AM | #7 |
Happy to be here
Just for reference, you can get them at Street & Performance too. Here's mine that I was checking for fit on my mower..
11-16-2006, 04:15 AM | #8 |
A guy with a truck
N2TRUX or anyone else actually fit these on an engine in a truck yet? The S&Ps look promising except for the possible mount intereference.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
11-16-2006, 10:04 AM | #9 |
Happy to be here
The S&P headers worked just fine. For point of referrence, the LS1 was mounted using S&P adapter plates. I had no clearence issues at all on the headers. I did have to notch my frame for the a/c compressor because I wanted to run the stock F-body brackets.
Now I have a new front clip custom fabbed by Stoked Out Specialties...
11-16-2006, 11:29 PM | #10 |
A guy with a truck
Was this with the 73-87 style 'clamshell' mounts? I will be using these in my '72. I thought the S&P plates were for the earlier style mounts.
