Old 09-05-2006, 12:17 PM   #1
68crum
Proud owner of a P.O.S.
Np 208
is there any difference in the np 208 transfer cases if i going to use one from an auto truck in a manual truck?
68crum is offline   Reply With Quote
Old 09-05-2006, 01:08 PM   #2
44th Miss Inf
Re: Np 208
68crum,
The 400 trans and 465 have the same input splines. The 350/700r4 use a smaller input shaft.
Virgil
44th Miss Inf is offline   Reply With Quote
Old 09-05-2006, 01:26 PM   #3
68crum
Re: Np 208
i'm new to the 4x4 world. don't know the kind of trans it has only that it is a 4 speed with granny low and a np 208TC that is cracked. i have another 208 that is in good shape but it is from an auto truck. is it a direct swap? or do i have to change some stuff? its an 81 k10 if that helps.
Old 09-05-2006, 09:51 PM   #4
44th Miss Inf
Re: Np 208
The 4 speed, if reverse is away from the driver and down (towards the seat) is an SM465. If reverse is to the driver and down, it would be the old SM420.
The standard trans and 400 auto trans input is 32 spline. The T350/700R4 has a 27 spline input. You can change inputs from case to case. Well, about everything should interchange between the 2.
Just make sure they are GM cases, as Dodge, Ford and Jeep also used the 208. ALL the GM cases I've ever seen had 208C on the tag. I can't vouch for the others.
Can anyone else say if they would be a 208D, 208F, and 208J?
Virgil
Old 09-06-2006, 12:01 PM   #5
68crum
Re: Np 208
Is it easy to swap the shafts? Or should it be done by a pro?
Old 09-06-2006, 05:38 PM   #6
44th Miss Inf
Re: Np 208
68crum,
the inputs are not that hard to change, just a bit of time consuming if you haven't done it before. I can scan and send you an "exploded" view of a 208 case if you want.
Can also try to explain how to do it.
Virgil
Old 09-07-2006, 08:50 AM   #7
68crum
Re: Np 208
Originally Posted by 44th Miss Inf View Post
68crum,
Virgil
Man that would be great, and money saving.
Old 09-07-2006, 11:44 PM   #8
44th Miss Inf
Re: Np 208
PM me your email address and I'll get it out to you.
Virgil
Old 09-10-2006, 06:29 AM   #9
rcbildr
rcbildr's Avatar
Re: Np 208
I just changed out the input on my NP-208. It wasn't that difficult at all.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
