Old 09-13-2006, 02:35 PM   #1
JustLiveIt
JustLiveIt's Avatar
TH400 Trans Cooler Line Location
I have searched for the last half hour and can not find the thread that talks about which cooler line goes to the top fitting and which one to the bottom fitting on the turbo 400.
So can anybody provide the link or tell me if its top of rad to top fitting and bottom of rad to bottom fitting?
Thanks, Mike
1968 Chev SWB Fleet with GMC Clip and lots of 71-72 parts!
JustLiveIt is offline   Reply With Quote
Old 09-13-2006, 04:37 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: TH400 Trans Cooler Line Location
The lower fitting on thje trans is pressure out, & goes to the lower fitting on the radiator. The cooler feeds from the bottom to the top to eliminate air bubbles...... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-13-2006, 04:43 PM   #3
JustLiveIt
JustLiveIt's Avatar
Thank you very much!
I know I saw the answer to my question a few months back but could not find the thread.
Mike
Old 09-13-2006, 08:09 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here's a diagram I saved that shows how they go.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 09-14-2006, 12:19 PM   #5
JustLiveIt
JustLiveIt's Avatar
Thanks so much!
I got the lines on and the higher pressure "hot" line leaks. Any suggestions or should I just get her as tight as I can?
I have gotten so much info from this board that I could not put off becoming a site supporter anymore!
Old 09-14-2006, 12:39 PM   #6
mrein3
mrein3's Avatar
No offense but that picture is a bit misleading IF YOU LIVE IN A COLD CLIMATE AND DRIVE YOUR TRUCK IN THE WINTER. (I know the orginal post was from somebody in Cali but others read these posts).
You southern guys want your hot fluid going to the radiator FIRST, then the auxiliary cooler, then back to the tranny.
Up north in the winter you want to send your fluid first to the auxiliary cooler then from their to the radiator to HEAT the tranny fluid.
Too cold can be just as bad as too hot.
One overly anal guy I know up here re-plumbs his winter to summer. He also waits until his tranny temp gauge reaches 100F before he takes off.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 09-15-2006, 12:33 AM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
That's an interesting concept. The only problem is that liquid to liquid transfers heat a lot faster than air to liquid. Therefore if you wanted to heat or cool the trans fluid faster you have to send it to the radiator first.
My contention is that the trans fluid is going to heat faster and get hotter than the coolant anyway due to the torque converter slippage and the pressure generated by the front pump.
The picture I posted shows how the lines are routed with a cooler in the circuit and the op did not ask for that. Most guys run one so it is pertinent. The original chevy gmc trucks did not come with a cooler anyway and they used them up north without any issues.
Anyone who reads any post in these forums must draw their own conclusions about whether the information they read is factual or flawed. That's my disclaimer, LOL.
VetteVet
