09-14-2006, 01:08 PM | #1 |
Air Ride List. What else do I need?
3/8" OD x 3/8" NPTF Male Branch Tee 13.32
Firestone 224c 2600 139.98 3/8" SMC Valve 8 Pack (Free Shipping) 219.99 Viair 450 150 PSI colorChrome 189.95 67-87 Fullsize Chevy Single Port Upper Plates 34.99 Firestone 255c 2500 139.98 Black 5 Gallon 8 Port 54.99 SMC Water Trap 3/8" 29.99 110/145 PSI Non-Adj 18.99 3/8" OD x 3/8" NPTF Male Elbow 19.20 Airlift Easystreet 200 PSI Single Needle 29.98 Airlift Easystreet 200 PSI Dual Needle 59.98 25ft of 1/4" DOT Reinforced Air Line 5.99 50ft of 3/8" DOT Reinforced Air Line 19.99 Subotal: 977.32 What all am I missing for the air ride setup? |
09-14-2006, 03:15 PM | #2 |
Re: Air Ride List. What else do I need?
What about switchs and wiring?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
09-14-2006, 03:48 PM | #3 |
09-14-2006, 06:40 PM | #4 |
where are you going to mount your tank?
09-14-2006, 08:20 PM | #5 |
09-14-2006, 09:34 PM | #6 |
The LuvShack Garage
I need my wiring run, wanna come to my cookout and help ? ? ?
09-14-2006, 09:48 PM | #7 |
09-14-2006, 09:57 PM | #8 |
The LuvShack Garage
09-14-2006, 10:06 PM | #9 |
You probably woudn't want me to mess with anything you have since I have never messed with air ride. I do have a list of chores that need to be done to mine. Lets see here, remove body panels, shave door handles and marker lights, sand door jams, shave gas filler neck and install fuel door, find a 1/2 top, make custom bed cover, install 3.73's and eaton posi, install rear disk brakes, put headders on, run the satinless exhaust, install the edelbrock pro flo, block sand all body panels and paint. I hope I will be happy after I get all this done. So anyone want to come help poor old me out?
09-14-2006, 10:11 PM | #10 | |
09-14-2006, 10:21 PM | #11 |
its just $$$$$
09-14-2006, 10:38 PM | #12 |
09-15-2006, 01:44 PM | #13 |
09-14-2006, 11:00 PM | #14 |
computer illiterate
my buddy at work is BIG in the mini scene and he tells me the viair460 is a better compressor and they dont make the 450 anymore so if you ever need parts for it they may be scarce
72 2wd blazer 72 swb 4x4 |
09-14-2006, 11:15 PM | #15 |
Happy to be here
Just so you know the ViAir compressors are very good, but very LOUD. Plan on mounting it as far back as possible.
Unfortunately this still isn't far enough...
09-15-2006, 01:54 PM | #16 |
are you just going to have front and back control or sides also
you might want to think about a higher psi presure switch cause 145 might have a lil trouble lifting the front and you are probley going to want some check valves so you dont get air blead back from tank to comp or from bags back to tank do you have the brackets for the back bag mounts and for the lower on the front |
09-15-2006, 02:02 PM | #17 | |
Global warming is a myth
Later, Buddy
Henderson, NV 1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!! 1990 K5 with 37's 2003 Discovery SE7 - Wife's |
09-15-2006, 02:16 PM | #18 | |
he has a very good point belt drivencompressors make no sound and have a very high output you just have to find a way to mount it witch means if no company makes a bracket you have to fab one and the cost is more i have one on my silverado and have loved it 4 the last 4 years i only went with elect on my blazer cauase its not going to be my daily driver only a summer cruiser |
09-15-2006, 02:34 PM | #19 | |
09-15-2006, 03:38 PM | #20 | |
Later, Buddy
09-15-2006, 03:42 PM | #21 | |
09-15-2006, 04:06 PM | #22 | |
Thanks, Kade |
09-15-2006, 08:37 PM | #23 |
front end down
this is with about 100 psi |
09-17-2006, 09:12 PM | #24 |
Chevy Truck Addict
N2TRUX:
Could you provide me with some detail on your rear setup. I have a leaf rear-end on my 70 SWB and will be baggin' it this winter. Are those the F9000 bags? If so, do they have a 1/4" air inlet? The reason I ask is that I don't want to overbuild my system. I want to have basic control (front / back) and am not too concerned about speed. I notice that a lot of folks are running 1/2" valves and lines. If the inlet size is only 1/4" then why do I need a 1/2" valve (get my drift). The fill speed is only going to be as fast as the smallest component. Any details you could provide would be greatly appreciated. Thanks.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
09-19-2006, 01:39 PM | #25 |
there are alot of factors in building a set up and keeping the leafs on that type of set up you can only get as low as you can lower it and then you use the bags to go up from there i will get you sone picks of leaf set ups most of the ones we do are link set up but i can give you a few ideas
and the bags are slam spec rs72 they have 1/2 ports i know that speed might not be a factor but just keep in mong if you go all 1/4 it is a lot of work to make it go faster if its too slow of you dont have enuff pressre for the amount of weight you need to lift and if you start with 1/2 and its too fast you just have to reduce it down to slow it down and they make adjusters that go in line to do that |
