09-15-2006, 09:51 AM | #1 |
Active Member
Backspacing question?
I'm gonna order 15x10's for the back but i need the backspacing so they wont stick way out of the bed and look goofy. the tires are 295-75's. i wanna keep them nicely tucked within the bed oh and about the front....would 15x7's look silly on the front? or how about 15x8's? help me out folks!
09-15-2006, 01:14 PM | #2 |
Licensed to Thrill!
Re: Backspacing question?
I am pretty sure my Cragar's are 4.25" backspacing and they are 15X10's.
Here's the best shot that will give you a profile of that. Someone will be able to verify that is the correct backspacing though - it is standard. |
09-15-2006, 02:14 PM | #3 | |
Active Member
09-15-2006, 02:18 PM | #4 |
Active Member
Oh and here is the video of me breaking those new tires in.
http://videos.streetfire.net/video/3...0023085992.htm |
09-15-2006, 01:25 PM | #5 |
Active Member
I measured some 15x10s on the back of my truck (Havent bought the correct ones yets). For the WIDEST tires I could find that would fit under the bed, I came up with 5 1/2 inches of backspacing to tuck the wheel under the bed, but not mess up the look (track width). For the front I came up with 15x7s with 3 1/2 inches OR 15x8 with 4 1/2 inches, depending on your preferences.
Heres a link to the tires Im gonna use, and the mock up wheels I was using. http://web.mac.com/jason_hall/iWeb/T...or%20sale.html Jason ________ Eating disorders advice Last edited by Jayss109; 04-27-2011 at 11:40 PM. |
09-15-2006, 03:58 PM | #6 |
Active Member
If you can get your hands on a set of 15x10s, bolt them up and start measuring. Those tires that I want are actually 14 inches wide at the bulge. So I measured where the bulge would be in relation to the body, and that how I got my measurements.
RatRod67 has a sweet setup on his truck... measurements and #s are here http://67-72chevytrucks.com/vboard/s...d.php?t=191549 Jason ________ Free Itunes Gift Cards Last edited by Jayss109; 04-27-2011 at 11:41 PM. |
09-15-2006, 04:40 PM | #7 |
Licensed to Thrill!
Couple of more pics I found...
09-15-2006, 05:30 PM | #8 |
I put some Impala SS wheels on which are 17x8.5 with 5.125 backspace. The tire I have on the rim is close to the inside of the inner wheelwell on a fleetside. I don't think I would go any more than that...they might rub around corners. If you do get them on post some pics...
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
09-15-2006, 05:56 PM | #9 |
Active Member
So 5.00 backspacing would be about perfect? those pics are better orange, thanks!
09-15-2006, 06:52 PM | #10 |
I have 15X10 on my 72. 5 inch backspacing.
09-15-2006, 11:56 PM | #11 |
5 inch back spacing seems to be about right , but with the factory panard bar ( coil spring)the rear axle may not be centered between the wheel wells, so check that first.
09-16-2006, 11:26 PM | #12 |
I didn't see a year mentioned, but the 67-69 rears are about 3/4 inch narrower on each side than the 71-72 rears, 70 could be either. That 3/4 inch can be made up in the offset if you have an earlier rear.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
09-19-2006, 12:40 AM | #13 |
Active Member
It's a 69 shortbed.
