clutch replacement refresher
I have not changed a clutch in some time and i have never changed one on a 4x4, so if some of you guys could give me a refresher course. I guess i need a simple step by step for our trucks.
79 K20 Long Bed |
Re: clutch replacement refresher
Been there, done that...
Here something I posted on another board about a year ago. 12/23/04 1980 SM465/350ci Clutch Lever Help! OK, for a month or so the Throw out bearing has been buzzing - once in awhile. Figured I could wait till it warms up to fix it. Well, last Friday, I got 2 shifts out of it at lunch and It sounded like the Wheel of fortune - rapid fire clicks. and no clutch response - stays in gear. So, I read up and it looks like it may just need to hook my dangling clutch lever/arm back up to the T/O bearing and pivot ball. Stories over. Now the questions. 1) Can this be done without dropping the trans? Just shove in around the T/O and re clip it to the pivot? 2) Anything else to look for? 3) Can this be done on a weekend with 1 pot of coffee, 6 Dos Equis Cervezas, and "Salty Sam the Sailors Bawdy Language Guide"? Or do I sell the kids to the gypsies for professional drivetrain help? ONE WEEK LATER... OK! I've dropped everything, Replaced Pressure plate, clutch disk, flywheel, pilot and T/O Bearing. Bought a tranny Jack. Have the engine supported and levelled and trans is aligned. Alignment tool is removed. Why the heck can't I get the danged thing to go together?? Yes, I have re-checked the clutch alignment and I triple checked the pilot on the end of the shaft before installing it. I've spent over six hours under the truck trying to fit it! I'm open to suggestions. Maybe alignment studs in the mounting holes?? Any advice or help would be greatly appreciated. I'm missing out on Reno's heaviest snow since 1917!!!! Thanks!! - Dave ps: I've got $50 and a six pack for anyone in Northern Nevada wants to come by and make this work!! Our stories are similar. Round up some big friends. Put the truck on stands, high as is safe, all four corners. Get a trans jack. Remove the trans hump cowl and shifters. Pull out from below. I used an A-Frame and come-a-long from in the cab to help lower it. This SM465/NP205 combo is HEAVY!! As you read above, the re-install alignment of the pilot shaft into the bushing is the tricky part. Tricks: · Inspect the flywheel. Looks funny at all - spider cracks, hairlines, too shiny. Take it off and have it surfaced. · Change the trans and case oil while it’s out. · GET A NEW LEVER BOOT! Keeps the junk out that eats the T/O bearings. · Get a new lever, too. And an adjustable pivot ball. · Remember to lube the Z-Bar. · Think about a new trans mount on the cross member. The rest is easy. The weight and awkwardness is torture. If you have any other questions let me know. - Dave
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
