power booster
Has anyone put one from an 80's chevy truck on a 60-66 chevy truck. I have one so thats why I ask. Jeremy
Re: power booster
sorry , off topic , but really like the color of you truck... what color is it? any details you can share?
thx Last edited by Dadsredwagon; 09-17-2006 at 09:42 AM. |
Re: power booster
I really don't know. It was painted 2 owners ago, and the one I bought it from did'nt know either. If I ever repaint it I'll go with the same if I can figure the color out.
Re: power booster
We did to my mine (62' Stepside). along with the whole front crossmember, spindle to spindle, power steering, etc.
________________________ 62' ![]() 08' Chevrolet Silverado CrewCab 05'Toyota Tacoma Prerunner SR5 |
Re: power booster
What year power brake booster did you use?
Re: power booster
1986, booster, proportioning valve, master cylinder, etc. I have used alot of parts off the 86'.
i will shoot some pics tommorrow and post them here for you of the engine compartment so you can see.
________________________ 62' ![]() 08' Chevrolet Silverado CrewCab 05'Toyota Tacoma Prerunner SR5 Last edited by 62ChevyStep; 09-17-2006 at 10:58 PM. |
Re: power booster
You'll need to fabricate the mounting bracket and you might need to use part of the old push rod, but other than that, it should work fine. I bought the whole setup already engineered for my '66 from Chevy Duty $375.00 - came with everything including a zinc plated mounting bracket.
Greg Smith a.k.a. "The Highlander" 1966 C20 Custom Camper, 2017 Chevy Silverado 1500 Highlander's Project Pics Highlander's web site: www.6066ChevyTrucks.com |
#8 | |
Re: power booster
Prestige member Old Farts Club
Re: power booster
then I came across a 83 4x4 that I'm going to use the newer front axle and the 700r4 in my 61. [/QUOTE]
Did you do a conversion to 4x4 or was it that way ? if converted how hard was it to do?
Hey sombodys gotta do it! ![]() |
Re: power booster
Sounds good thanks!!
New Member
Re: power booster
I didn't have the bracket for my booster either, but I just mounted it directly to the firewall on my '64. The firewall was flat, so i figured it would be alright. Just had to add some threaded rod and a clevis to the cab side to attach to pedal. works like a charm.
Re: power booster
here are some current pic's
#13 | |
Re: power booster
Re: power booster
Thanks 62 chevy step, wow real close to my handle(62 short step). Can't wait till I start on mine. The power brakes will help alot on the 61 4x4!! Thanks again for the pics.
#15 |
Re: power booster
i just put a 1973 booster on my 64 c10 yesterday.the booster bolted right to the old master cylinder holes.the push rod was too short but the rod end unscrewed so i used a barrel nut and a piece of allthread to extend it.i had to drill the hole at the pedal from 1/2 to 9/16.
1964 c10 short step 1962 econoline van 1989 rs camaro 2006 yamaha vino 125 1975 goldwing |
#16 |
Re: power booster
Thanks Zenish, I'll let yall know how it went when I get it done.
#17 |
Re: power booster
It is a factory 4x4. Just going to put an open knuckle axle with disc brakes, power steering,etc.
