09-18-2006, 09:43 PM | #1 |
Out of the carpool lane.
Front left disk brake is locked up
My truck has been sitting outside for about 6 months without moving and my front left disk brake is locked up. I drove it around the yard today and it seemed to have loosened up a bit, but is there anything else I could do to unlock it and burn the surface rust off the rotors?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
09-18-2006, 10:07 PM | #2 |
Re: Front left disk brake is locked up
When I bought my truck I had the same problem, I never could get it to unlock other than temporarily. on the way home it would lock up everytime I stopped and would finally unlock again when it got to hot, but I was planning a frame off so I didn't care if it screwed up the rotor or anything.
Drew '71 Chevy 350/TH350 Hugger Orange Currently just a rolling frame, body work soon to follow!!! Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927 Daily Driver: 1997 Chevrolet S-10 with more gears than pistons |
09-19-2006, 08:57 AM | #3 |
Throbbing Member
Same problem here with the left front. I ended up just doing a complete brake upgrade. I was reading a post here in the last few days though were someone said it ws caused by a blockage in the line where it attached. Hope this helps
09-19-2006, 09:06 AM | #4 |
Rottenwood Garage Member
Those loaded calipers are about $15 at Advance and should take about 20 min. each side. Should be a cheap way to find out if its the caliper and you will get fresh ones out of the deal. The last 2 times I had that problem it was the caliper.
