Old 09-21-2006, 02:12 PM   #1
jimmydean
jimmydean's Avatar
I'm at a loss with this front end!
I am trying to do these spindles and nothing will come off! Looking at the walkthrough on Classic Trucks, it looks liike everything fell off once it was unbolted.
I have all the castle nuts removed from the tie rod end, upper and lower ball joints, but the thing won't budge! I am headed to Autozone for a puller even though one wasn't used in the walkthrough.
I have soaked everything in WD40 in hopes that would help. Any advise before I beat things to hell?
jimmydean is offline   Reply With Quote
Old 09-21-2006, 02:18 PM   #2
68haywagon
I'm watching you!
Re: I'm at a loss with this front end!
It took a BFH to get my spindles to seperate from the ball joints. A few whacks on the side of the spindle where it connected to the ball joint did it for me.
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 09-21-2006, 02:23 PM   #3
Jim_PA
I'm assuming you have the lower control arm supported, and you have a chain or spring compressor holding the spring in there? Otherwise, it could come flying out, and ruin your day bigtime!!
All it took for me was a BFH as well. I just left the castle nuts on there loosely, and gave them as good of a shot as I could.
Jim_PA is offline   Reply With Quote
Old 09-21-2006, 02:26 PM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
I did the same. BFH all the way! I too left the nuts on some so nothing would fly out (I also used a spring compressor, but it is not necessary.)
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 09-21-2006, 02:34 PM   #5
68haywagon
I'm watching you!
I did leave the nuts on about half way.
Old 09-21-2006, 03:31 PM   #6
BowTieOgre
Im going to agree with the others, I tried to finesse mine out but it all came back to the BFH.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 09-21-2006, 03:41 PM   #7
ChevyDude
BFH....it's the ticket!
ChevyDude is offline   Reply With Quote
Old 09-21-2006, 03:45 PM   #8
70GMCer
70GMCer's Avatar
An for those of you who do not know what a "BFH" is, I cannot say that on here.....lol
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 09-21-2006, 03:51 PM   #9
cdowns
cdowns's Avatar
it just amazes me the money people will spend on parts on these trucks , BUT not the $25 to buy a service manual to learn how to do it right // just beat it with a hammer good idea
Old 09-21-2006, 11:38 PM   #10
72 CustomCamper
huh ???
72 CustomCamper's Avatar
BFH= Big Freaking Hammer
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 09-21-2006, 04:22 PM   #11
jimmydean
jimmydean's Avatar
I have the service manual, but they make it look like it just slides ride off.
I put a jack under the arm to support the spring, then I got the fork from Autozone and that did the trick for all three (upper, lower, and tie rod). I guess I need a BIGGER FH
Old 09-21-2006, 04:48 PM   #12
70c10
67-72 Addict!
70c10's Avatar
jimmydean, I got the same kit from Paul and hope to start on it next month. That article makes it look too easy. If you run into any little problems could you let us know what to expect?. I saw a post recently about possibly having to do some grinding or something to make the spindles fit. I will have to search for that again to see what the fix was. Keep us posted and snap a few pics if you can. Good luck man!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 09-21-2006, 04:53 PM   #13
67ChevyRedneck
If you use stock 71-72 spindles on stock 67-70 A-arms the bump stop on the spindle will hit the bump stop on the A arm. You just need to grind a little off the "tit" to get your full lock to lock steering (may want to count how many times your wheel turns lock to lock.) If you buy spindles in a kit, I think they compensated for this in the kits so no grinding is necessary.
Jesse James
Project "On a Dime"
Old 09-21-2006, 05:47 PM   #14
jimmydean
jimmydean's Avatar
So far it has been somewhat easy. The only advise I can give at this point is to soak the whole setup in a good degreaser (I use an orange based non-toxic cleaner) the day pr night before, then power wash the hell out of it.
37 years of crap is tough to get through. You will also want to soak bolts in liquid wrench or something too. Getting the brake lines off was a PITA. I will be running all new lines soon. I also want to pull the rhole front end apart, but I don't have time to do that this round.
