Old 08-12-2002, 08:59 PM   #1
69mychevy
yes i did post something
My truck broke down at car toys and must be fixed in an hour time frame tomorrow
My truck broke down while it was in the shop at car toys gettin an alarm put on, it is getting juice into the distributor but no spark from the spark plugs, i hav hei ignition. in the morning i have to go and try to fix it can you guys please list some of the most likely things it could be. it was workin fine then it just stopped. please help i really gotta fix it in the mornin
you can want in one hand and s h i t in the other and see which fills first
NO MATTER HOW BEAUTIFUL THE GIRL(S) IN MY AVATAR IS PLEASE READ MY POST
69mychevy is offline   Reply With Quote
Old 08-12-2002, 09:01 PM   #2
mooneyes
mooneyes's Avatar
replace the module in the hei....99.9999999% of the time thats the only thing that goes bad..and usually the go right now..no worning
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 08-12-2002, 09:05 PM   #3
69mychevy
you mean the ignition controller module with 2 wires comin in and 2 goin out?
Old 08-12-2002, 09:07 PM   #4
mooneyes
mooneyes's Avatar
yes and dont forget to put the grease that comes with it on the bottom
78 caprice project
Old 08-12-2002, 09:15 PM   #5
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
The one in the distributer taking place of the points.
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 08-12-2002, 09:17 PM   #6
Gordo
Smile
I agree, and if that distributor has lotza miles on it check the wires from the pickup coil under the module that plug into the module to see if they have broken from many miles of advancing.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 08-12-2002, 09:18 PM   #7
smitty62
smitty62's Avatar
Also could be the pickup coil under the module--the small wires on these break off pretty regularly.
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 08-12-2002, 09:22 PM   #8
69mychevy
gordo, can you explain that better?
Old 08-12-2002, 09:23 PM   #9
69mychevy
and you 2 smitty i don't understand this distributor stuff very well
Old 08-12-2002, 09:34 PM   #10
Gordo
Smile
Unfortunatly the pickup coil is not highly visable with out removal and dissassembly of the distributor, but if you remove the cap and rotor then unplug the module, one of the two plugs wires will "disappear" under the plate that the module mounts to, these lead to the pickup coil, if they have broken off under there you should be able to tell by gently tugging on the wires independently. If they have broken off it would require removal and dissassembling the distributor to replace the unit.
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1951 Wife
Old 08-12-2002, 09:38 PM   #11
69mychevy
aight thanx gordo, im still confused but we'll see what happens, smitty could u explain what u said a lil better too?
Old 08-12-2002, 09:41 PM   #12
smitty62
smitty62's Avatar
Go ahead and stick a module in it because it's easy--if that don't fix it, you need to pull the distributor out--remove all the innards down to the small coil around the shaft--check the wires fastened to it by pulling on them easy!! DON"T pull them out! Sometimes all that is holding them in place is the insulation. If the wires are broken replace it. Use the silicone that comes with the module. Some guys can do all this without pulling the dist. out--my belly's too big!
Smitty
Old 08-12-2002, 09:48 PM   #13
69mychevy
ok well to tell you guys the truth i don't understand any of that right now cause i've never actually had a distributor apart but im gonna print your comments and take them wit me when i go work on it thanx for your help
Old 08-12-2002, 10:25 PM   #14
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If you listen to your tunes with the ignition switch on the run position, then a burned up coil is another posability. Also if you run excesive gap on your plugs the coil can burn up too.
Old 08-13-2002, 12:28 PM   #15
69mychevy
i pulled it apart and alot of it was rusted, i replaced distributor cap, rotor, coil, and module, and soon i will replace the wires and plugs but it runs fine and is home now thanx alot to all you guys!
