Old 09-23-2006, 02:26 PM   #1
jenpen400
VIN decoding
Just trying to find out what "Mater" is from the drivers door jam I get this number CS30V-SA35852 it has side marker lights so I'm guessing it's '68 or younger any help would be helpful. It is an old ranch truck,GMC 3500 badging on the cab It's a dually.
jennifer
jenpen400 is offline   Reply With Quote
Old 09-23-2006, 10:10 PM   #2
Rod
Re: VIN decoding
Simple
if you know GMC vin decoding
C = conventional cab
S = six cylinder
3 = 1 ton gvw range
0V= cab and chassis
- = it means nothing. If there was a letter in there instead of the dash' it was typically for the state of Pennsylvania. usually a K or T represented state requirements met
S = St Louis assembly plant
A = 1969..so it no 68 like you thought
35852 is the sequence number
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 09-24-2006, 02:46 PM   #3
jenpen400
Re: VIN decoding
Thanks!
