Old 09-26-2006, 03:17 AM   #1
gringoloco
A guy with a truck
gringoloco's Avatar
C-notch a step notch
OK. Fully prepared to be flamed and called ten kinds of dumbass, but I'd like to know pros/cons of trying this.
Keep in mind that the truck will see almost no load and very little tongue weight. Jetski at the most on a trailer. This will allow the step to be 2.5 inches shorter, therefore protrude into the bed 2.5" less.
This looks like a good idea and a bad idea at the same time to me. Comments/ suggestions/opinions/science backing up your comment/suggestion/opinion welcome.
-Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-26-2006, 11:54 AM   #2
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: C-notch a step notch
Well, the weakest point will definitely be the middle.... If you ever got rear-ended that thing would fold up like an accordian.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 09-26-2006, 12:43 PM   #3
Shane
Shane's Avatar
quick question ... why the C in the step? is the step not enough? if not, why not build the step just a bit taller?
not bashing ... just curious
Shane is offline   Reply With Quote
Old 09-26-2006, 10:29 PM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
The idea is to have a shorter notch overall, therefore, less intrusion into the bed area.
Instead of an 8" notch, you could shorten it to 5.5 and still have the same axle clearance.
-Chris
Old 09-26-2006, 10:49 PM   #5
Shane
Shane's Avatar
Gotcha.
Old 09-26-2006, 01:19 PM   #6
jimmydean
jimmydean's Avatar
I understand the idea, but I would agree that it would be the weakest link for sure.
I guess I'm old fashioned in the fact I use my truck as a truck, otherise I would have gotten a car. I have toys to haul and a horse to tow, so I need my frame as solid as possible.
jimmydean is offline   Reply With Quote
Old 09-26-2006, 10:55 PM   #7
smbrouss70
smbrouss70's Avatar
Keep in mind that you still need clearance for the differential, not just the axle tubes. So if the thickness of the frame where the c-notch is (will be?) is less than the height from the top of the axle tubes to the top of the differential, the diff will hit the bed floor before you bottom out the notch. In my opinion just use rectangular tubing on the top side of the step notch that is just thick enough to allow for the diff.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 09-27-2006, 12:43 AM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
Yeah, I was thinking that as I was typing my last reply. Sounds like a solid plan.
-Chris
