09-26-2006, 12:21 PM | #1 |
Using C-channel for the back half?
I have decided to not build a complete frame from scratch and just modify the stock frame. I am going to rebuild the back half similiar to the pic i borrowed from FNLOW69. Hope he doesn't mind. I was wanting to build it out of 2x4 C-channel. The reason i want to use C-channel instead of tube steel is because i am going to be puting the gas tank behind the rear axel and would like to have all the fuel lines and brake lines protected inside the channel. They have 3/16 and 1/4" C-channel. I was thinking about using the 3/16 and then puting a large piece of 3/16 steel on the inside and outside for extra stength (gussets). What do you all think about this? The factory frame is made out o 1/8 C-channel so i don't see how this will be weak or bad. Please give me your opinion. Thanks
Here is a pic on how i am going to do the rear end. |
09-26-2006, 12:40 PM | #2 |
Re: Using C-channel for the back half?
use tubing and Kugel Klamps for your lines ... much stronger and looks much more gooder.
09-26-2006, 02:10 PM | #3 |
It never ceases to amaze me how many ways to build/engineer these trucks! That is peel the reflectors of the road low, wow!!
09-26-2006, 06:15 PM | #4 |
[QUOTE=Shane;1813635]use tubing and Kugel Klamps for your lines ... much stronger and looks much more gooder. [/QUOTE
tubing is by far the better choice// you can also cut access holes and run the tubing inside the tube for an almost completely hidden effect// but you could always use the c-channel and if it fails then you can use tubing the second time around if you survive
09-26-2006, 03:06 PM | #5 |
What about when people Z the frame they cut the stock C-channel and weld it back together and people think that is okay but when it comes to the rear it has to be done in tube steel? I think if it is done right you will be plenty strong enough. The reason i am so for the C-channel is because i don't like the way the frame looks when you go from C-channel to tube steel. I know that tube steel is stronger but is it overkill? Thanks for thoughing out your comments. Josh
09-26-2006, 06:08 PM | #6 |
How do you get the box to fit when the frame is modified like that?
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
09-26-2006, 09:46 PM | #7 |
09-26-2006, 09:44 PM | #8 | |
Do whatever ya want, but there is a reason why you can't purchase a back-half made from "c" channel from any chassis company. Tubing is better, stronger, and the smartest way to mod a frame. Last edited by Shane; 09-26-2006 at 09:47 PM. |
09-26-2006, 07:07 PM | #9 |
i dont know about you but i dont like to build things "strong enough" i like it to be fail proof. i'd go with the 2x4 rectangle tubing.
'67 c10 350/th350 |
09-27-2006, 08:48 AM | #10 | ||
Happy to be here
Yes you can use C-channel but it will look bulky and weigh much more than rectangular tubing. As Shane mentioned take a look at any "professional" built chassis and you will see rectangular or round tubing. They do this for a reason. Quote:
09-27-2006, 10:43 AM | #11 |
Well you guys talked me out of it. I will use tube steel. Thanks for the comments. I really appreciate it!!!!!!!
09-27-2006, 12:02 PM | #12 |
If I had the room and the tools (as I hope to some day) I would love to build a complete custom frame from 4130 round tubing. Light, strong, and sweet!
