Old 09-26-2006, 04:25 PM   #1
84 400
Sb 400 club
84 400's Avatar
2000 Tahoe Front wheel hub replacement
Well i know that this is a commen Prolem on 4x4's. This tahoe is a 2000 with 115k on it and there was a funny nosie comming from the front end. sounded like a bearing and since it was going in today to get the tranny flushed we figured we could have the dealer check it out. And i was right it was the front drivers side wheel hub. Now they want 582$ to replace the hu. I have done it on a jeep before so i think i would have n problem doing it on the tahoe. Any special tools i would need? A torque wrench, and a hub puler should do right?
Any tips or tricks to doing these?
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 10-02-2006, 12:13 AM   #2
84 400
Sb 400 club
84 400's Avatar
Re: 2000 Tahoe Front wheel hub replacement
no high milage 4x4 out there with this problem?
1985 C10 LWB Sold
Old 10-02-2006, 01:59 AM   #3
TheLlama
No special tools... just time and beer.
TheLlama is offline   Reply With Quote
Old 10-03-2006, 05:42 PM   #4
84 400
Sb 400 club
84 400's Avatar
ha ha yeah. well are the calipers held on with tork drive? I don't have any so i will need to know the size to get one. Thanks
1985 C10 LWB Sold
Old 10-03-2006, 07:29 PM   #5
Josh
He's got mean nasty FANGS!
Josh's Avatar
Caliper brackets should be held on with 18mm head bolts. The back of the hub has 3 15mm bolts, and I forget the size of the 4x4 axle nut.
On jackstands it shouldn't take more than an hour or two to get off, hardest part is getting the 3 bolts that hold the hub one off. With air tools and a lift I can do them in around 45 minutes or less.
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
Josh is offline   Reply With Quote
Old 10-03-2006, 08:28 PM   #6
84 400
Sb 400 club
84 400's Avatar
Head bolts? so am i to belive they are regular or are the special? i am not up on my lingo. I was thinking about trying to lossen the 3 bolts while the truck was on the ground so i can really lay into them. i hate working on stands cause i don't truck them. I have the tools i think and i need the hub puller right?
Thanks it is my dads truck so normally don't work on it if you can't tell
1985 C10 LWB Sold
Old 10-03-2006, 09:29 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
I think he means "hex" head bolts...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-03-2006, 09:39 PM   #8
bluewhitepete
chevy72402 under a new name to get past a ban
you won't need a hub puller just a big hammer and a punch, make sure not to damage the axle. When installing it clean the rust and dirt from where the old bearing was and install the bearing by using the 3 bolts on the backside. make sure you route your wiring correctly and that the hub assembly is positioned the way you took the old one out. good luck, it is pretty simple though..
bluewhitepete is offline   Reply With Quote
Old 10-04-2006, 04:53 PM   #9
84 400
Sb 400 club
84 400's Avatar
thanks N2 and blue, i thpought they were hex head. Well i ordered the parts today hopefully they are in by this saturday
1985 C10 LWB Sold
