Questionable
I am trying to find a 90 degree elbow-to-nipple for the low pressure side of my power steering gearbox, but I don't have a clue what thread and flare the low pressure side and high pressure side are.
Can anyone clarify on this? I wanted to find something online or at a local store ASAP. My low pressure line is almost the only thing standing between me and having a complete working power steering setup for firing up my engine in a week or two. THANKS!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Questionable
Re: Power steering gearbox - what thread/flare size?
ttt
I'm not sure (I've put the lines on my power steering gearbox but haven't installed it yet), but I think the two connections are both 3/8". One is 3/8" flare & the other is 3/8" NPT.
I'm very curious to know for sure. I don't know if I'll get to it this weekend or not. Please let me know your results if you beat me to it. ![]()
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
#4 | |
![]() Join Date: Nov 2004
Just a thought. Good luck! I want to see some video when that thing is running!!!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 10-04-2006 at 02:15 PM. |
Questionable
therein lie the problem - i don't have the part
4 bolts, 2 nuts, and a pitman arm? Can't be that hard to take off
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
member #16
![]() Join Date: Dec 1999
Shifty heres a pic of the lines on the box. The return is the one to the outside and the hose clamps on after it crosses the frame rail. Both lines are 3/8 steel tube , but I would check the hole size in the box. Something in the back of my head is the fitting is a little larger on return. I may be wrong an that. Both fittings are inverted flare. The pressure side is standard 3/8 inverted flare. LMC does have a return tube in their catalog.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 10-04-2006 at 05:59 PM. |
What is the thread size of the nut for the pressure side? 5/8ths or 11/16ths on a 72 C10 gear box?
TKX |
Questionable
Thanks!
I would love to just use a 90º 3/8 NPT flared (or whatever it may be) to a tap. I guess my big question was what kind of flare it was and if it was 37deg or 45 deg flare. It's not very clear when looking inside the hole. It looks like one would be flared and the other wouldn't ![]() I bought a kit at the store - but they only list the pressure-side hose and NOT the low pressure hose.
you need an INVERTED flare - standard 37 & 45 degree external flared fittings won't work
How about something like this? It should be pretty easy to find a female 90* nipple that would then attach to this.
http://detroitspeed.com/productpages...gs_us_prod.htm
My 51 project http://www.cardomain.com/ride/2285825 My 68 Camaro project http://www.cardomain.com/ride/2277404/1 |
#13 | |
Questionable
I was at Summit's big store today and looked at their replacement box for our trucks. Both high pressure and low pressure side use an inverted flare, but the low pressure side appears to be a smaller line. one looks to be 3/8 (high) and the other 5/16 (low)
Questionable
Ah, So I just read more on the whole AN flare thing. I guess they are always 37º - but I remember seeing a lot of 45º inverted flares when I initially started looking at replacing my lines. Lots of stuff I didn't know in this PDF:
http://www.parker.com/tfd/fittingsol...ANFITTINGS.pdf Lots of good info here: http://www.durexpowersteering.com/techtips.html That same company makes rebuild gearbox parts for our trucks and older trucks! ![]() I guess what I don't really get is whether you can use an SAE inverted flare in place of an AN inverted flare? They both seem to be flared at 37º....talk about confusing crap. ![]()
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 10-05-2006 at 02:12 PM. |
#15 |
Questionable
This is essentially the piece i am looking for:
http://midamerica.thomasnet.com/view...bow?&forward=1 Sorry for the triple post.
#16 |
The .pdf link you posted comes from the company that I worked for for almost 10 years ... Parker Hannifin.
We made 37 degree fittings by the gazillions in all shapes, sizes, materials, and configurations. As far as inverted flares being at the same angle ... yes, as long as you specify a 37 degree inverted flared fitting. The adapter fittings for brake lines are made this way. The inverted flare goes towards the brake line (flared brake line against the inverted flare makes the seal) and the AN fitting is on the opposing end for the connection of the braided line. There ARE some 45 degree fittings ... but they are application specific and most times for very high pressure hydraulic connections. Not normally seen in automotive applications. Last edited by Shane; 10-05-2006 at 03:13 PM. |
#17 |
Questionable
So, would it be safe to say that if I'm looking at Ace hardware or some other similar place, I won't be finding any fittings w/45º inverted flares?
Between trying to find this 90º swivel inverted 3/8-to-barb nipple power steering adapter and a 7/16-14 2.5" carriage bolt.... What a pain in the ass. ![]() Thanks for the info, Shane.
#18 |
chances are you aren't gonna find automotive grade fittings at a place like Ace Hardware anyway, 45 OR 37 degree ... if you do happen to find fittings there at all, they will probably be made from brass and intended for natural and/or LP gas applications (low pressure).
I would continue to check with the automotive guys for a fitting that is designed for petroleum based fluids as well as higher pressures. Let me ask you this ... are you trying to put braided lines on your power steering setup? If so, these are already available (premade with fittings) from RB's Obsolete. http://www.rbsobsolete.com/product.a...duct_id=166155 I could have sworn I saw some on CPP's site as well, I was gonna post a link, but can't find them now. Sorry. |
#19 |
Questionable
I'm almost tempted to go braided, but that isn't what I want - and I would rather put $50-100 towards a new steering column than a low pressure power steering line.
This is my dilemma: I have no low pressure hose right now. I hae a modified high pressure hose to adapt to the LS1 though. For the low pressure line I need a fitting of unknown size (if it was AN, it would be at least one step larger than -6 AN) to a 3/8" nipple so I can run 3/8" hose to the PS return nipple. Every LAPS (local auto parts store) chain has my low pressure hose for our trucks listed as just that - a hose ... no fittings, nothing, no way to screw into the box. The high pressure line is correct, but the high pressure line looks (and I think it was) too large to fit in the low pressure side or I would use it ... well, i think it uses larger than 3/8 rubber line also. So, basically...I need an adapter for my low pressure side and I have no clue what size or thread it should be. I want a 90º swivel with male inverted flare on one side (to the gearbox) and a barb or nipple on the other. Kinda like what I linke in my last post. It's been a bear to find one also - I have a male-to-male fitting that screws into the pump, but I do not know how to determine what size it is ![]()
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 10-05-2006 at 11:32 PM. |
#20 |
go visit napa, and tell them you need to look through their weatherhead, we have over 300 different brass pieces and then over 20 differenent sizes in those 300 different pieces, if napa cant get you the right brass piece, it probably isnt made
1969 c10 stepside 250 inline six, 4speed granny tranny, 4.11 posi rear end |
#21 |
Questionable
is their "weatherhead" the catalog bible they have? doesn't do me a lick of good to look at books - I need to know what size the dang fitting to the gearbox is suppose to be first.
again - i've been looking at catalogs for three days now by everyone from aeroquip to earl's to eaton and i have seen several parts that "look" correct, but nothing i've bought locally (wasted $20 already) "fits" correct. should i just go to Napa and buy another $50 worth of adapters that may not work? it gets frustrating after a while.
#22 | |
weatherhead is out line of brass fittings, from 8000psi hydrolic couplers to 1/8th compression fittings, most stores have a room or a wall of nothing but the weatherhead brass, so just start opening the drawers and look
#23 |
Shifty, I know the feeling...............I needed couplings to adapt the powersteering fitting to 3/8 NPT. NOBODY had what I needed and ended up rigging up my own, because I did not want to buy a million dollars worth of fittings and the setup didn't work. Now since the Hydroboost/powersteering/pump works, I got to go back and make it right. Which should be a challenge
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
#24 |
Shifty did you ever find the fitting? I'm looking for the same thing now.
#25 |
Questionable
Ok, McGaughy's sells both lines together as a pair - http://www.streetbeatcustoms.com/mcg63159-d3.html
I guess I can call them and see if they only offer the low pressure line. Will do that tomorrow.
