Old 10-04-2006, 12:59 PM   #1
TraderJon
TraderJon's Avatar
weird elec gremlins in dash bezel
Been a while since i visited, spent 2 days rebuilding my 67 dash bezel,installed a billet insert & painted everything,new bulbs (9),,,plugged it all in & things went nuts,left blinker shows right,,no dash lights at all,gas gauge not working,good fuse,,,,think maybe the printed circuit is bad?
Thought a board member here may have had a similar problem?
Mods,,If this needs to be moved to Elec section ,can you move it for me?
JFD
TraderJon is offline   Reply With Quote
Old 10-04-2006, 01:06 PM   #2
Aarons72s
Re: weird elec gremlins in dash bezel
I cant remember but can the electrical plug be put in backwards? I thought when I have cahnged mine out that yhe pulg on the wiring harness can go on both ways. I always just looked at the plu and saw that on all of them that one terminal wasnt used IE: didnt make contact on the cluster printed circuit and just lined it up that way. Thats my only thought. Any body else have some suggestions for TraderJon?
Aaron
Aarons72s is offline   Reply With Quote
Old 10-04-2006, 02:44 PM   #3
TraderJon
TraderJon's Avatar
Could be,,,i think the plug has a snap release on one side,,i'll go crawl under & look?
Thanks Aarons72s
Old 10-04-2006, 03:45 PM   #4
jhow66
jhow66's Avatar
Make sure your gauge cluster is GROUNDED to the dash metal.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 10-04-2006, 03:55 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
did you install a guage inst panel in a dummy light truck?
Old 10-04-2006, 07:24 PM   #6
TraderJon
TraderJon's Avatar
I didnt think about the ground,,,I just got through checking the power to it,got power,,,,either i'm getting fat (cold bullets)or these cabs shrunk..gotta be a contortionist to get to it.
thanks Jhow
Longhorn,,,,,It's a gauge panel,,the original to the truck,,although it has a 68 bed,,,driver door is 72,,,,goodmark hood,,,85 c10 disc brakes,,Monte Carlo tilt..kind of mixture,but it works good.
I figure it was something i did while i had it out,,,did notice a bad spot in the circuit,,but everything worked when i pulled it ecept 2 burned bulbs.
Thanks JFD
