Everything is work in progress
![]() Join Date: Apr 2006
![]() ![]() Any insight would be greatly helpful Last edited by cobinder; 10-11-2006 at 02:40 PM. |
Re: Dana 44 swap/gearing help
Those are the same gears. Your allowed 2% difference between front and rear. If the donor axle has 4.56s put it in and run it.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
How the heck do they change the ratio .01 without a completely different gearing combo? Or maybe they just rounded off LOL
thanks 454 |
Location: vacaville ca, because it as far from indy as i can be
are you sure its even a d44 in a 80? not unless some one put it there.
you are fine with the .01 off ratio, especialy being slightly faster in the front, it helps turning and whips the front around mudding. |
![]() Join Date: Mar 2003
Factory 1980 will be a corp 10 bolt in the front
I looked up the Bill of materials # off my 80 axle on the Dana website and it confirms it is a 44.
These two axles look the same except the donor has the spicer 44 big ole hubs. FYI Dana's site is pretty informitive. www2.dana.com/expert Time to cleaning and unboltin thanks for the input ![]() Last edited by cobinder; 10-12-2006 at 11:30 AM. |
