10-11-2006, 06:18 PM | #1 |
!!!!!!!!!!Brake problem!!!!!!!!!!!
Wooo Ole blue woooo. shew im havin a bad day with breaks. the rear breaks keep lockin up. i took everything off. thought they may be adjusted up to tight i backed them off and it seemed to make them worse. i have bleed them so i dotn think that that is what it is. the fronts seem to be workin no rust on the rotors. there was alot of break dust in the rear drums. also the master cylinder is leaking around the cap. i think i have it narrowed down to 2 maybe 3 things either the wheel cylinder or the mastercyclinder and i guess that the perpotioning valve could play a part in this as well. if anyone anyone else has had this problem any help would be great. ohh and the drivers side seems to do it the worst thanks for the help
10-11-2006, 06:50 PM | #2 |
Re: !!!!!!!!!!Break problem!!!!!!!!!!!
if you have not replaced the rear wheel cyl's do it ...even if they look good. REPLACE BOTH..
i had the same problem's and mine looked fine...as a last straw i replaced the wheel cyl's no more problems at all.. Last edited by rage'nrat638; 10-11-2006 at 06:52 PM. |
10-11-2006, 06:53 PM | #3 |
I survived Dead Man's Curve.
Are the wheel cylinders leaking at all? Dried up fluid can allow the brake pads to grab the drum too soon. Current situation on one of my trucks... the right rear locks up all the time.
Proportioning valve may explain some of it but I don't have much experience in that field to suggest anything.
"The people should not be afraid of their government. The government should be afraid of it's people." "The Hurricane" 1967 Chevrolet C10 350 Eight Cylinder, 700R4 BowtieOverdrive Cherry Bomb... Disturbing the Peace Since 1968. |
10-12-2006, 09:20 AM | #4 | |
Better late than never
1970 C/10 SWB Stepside |
10-11-2006, 09:29 PM | #5 |
the break dust in the drums was kinda gummy like it had been wet at one time i will replace the wheel cylinders first along with new pads. should i scuff the drums with sand paper to make sure there is no fluid left on them??
10-11-2006, 09:45 PM | #6 |
sufficiently talented fool
Replace the wheel cylinders and the brake shoes. Clean the drums with brakleen and then scuff them up with sand paper.
"it's impossible to be surrounded by idiots when you are part of the circle" 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board Last edited by centsless; 10-11-2006 at 09:46 PM. |
10-12-2006, 01:42 AM | #7 |
Or have them professionally turned.
"The people should not be afraid of their government. The government should be afraid of it's people." "The Hurricane" 1967 Chevrolet C10 350 Eight Cylinder, 700R4 BowtieOverdrive Cherry Bomb... Disturbing the Peace Since 1968. Last edited by ThatOneBlue67; 10-12-2006 at 01:43 AM. |
10-12-2006, 04:19 PM | #8 |
Re: !!!!!!!!!!Brake problem!!!!!!!!!!!
Just went and bought new rear wheel cyls for $11.88 ea. at Advance Auto...
1997 GMC Sierra Ext 1965 Mustang |
10-12-2006, 04:32 PM | #9 |
Brake stuff is SO cheap now a days it's best to replace as much as you can with new. You can scrub, adjust, sand and rebuild wheel cylinders all you want but you still might have problems. IMHO
Good luck! B-dub |
10-12-2006, 04:41 PM | #10 |
thanks for all the help guys im goin to get the wheel chylinders this weekend and hopefully that will do the trick
10-12-2006, 05:02 PM | #11 |
It is also very possible that the rubber hoses can collapse inside. My rt front on a chevelle I had years ago locked and wouldn't release, my brother told me to put a new rubber hose and well it worked. If both were locking I'd see check this and even if not the hose goes bad from the inside out.
10-12-2006, 06:57 PM | #12 |
I agree with 70rs/ss, replace the hoses
11-09-2015, 05:38 AM | #13 |
Did the wheel cylinders fix your problem?
11-09-2015, 06:49 AM | #14 |
laying low
This is an old thread from 2006 Ashdown. The original poster hasn't posted since 2007. Unlikely he is still around but you may get some help here.
11-09-2015, 06:55 AM | #15 |
Cool, I didnt see it was that old. Searcy Arkansas. I have spent alot of time there. It is a nice town. Have a great day!
11-09-2015, 07:09 AM | #16 |
laying low
Yeah hey neighbor. Searcy's a good place to call home.
Just what kind of brake problems are you having? Go ahead and post up your particulars and questions. Plenty of good people here to offer help.
