10-11-2006, 11:41 PM | #1 |
Señor Member
Question for the ultra-low
How much clearance in the trailing arm xmember did you add for your driveshaft?
As in...
10-12-2006, 12:07 AM | #2 |
its just $$$$$
Re: Question for the ultra-low
10-12-2006, 01:46 AM | #3 |
Epoxy Primer Friendly
not too much help here... Havent got the drivetrain back in yet
10-12-2006, 01:24 PM | #4 |
Señor Member
Like this...
10-12-2006, 12:49 PM | #5 |
Señor Member
Rats! You were two of the guys I was figuring would have the dimension I just picked up the above xmember, and want to raise and gusset that loop, but am not sure what's a reasonable distance. I've already got a 5" notch in the back of the cab, but can't find the actual needed height since the driveshaft bangs the stock xmember. Maybe I'll just go nutso and take it up to just under the seat.
10-12-2006, 01:44 PM | #6 |
That's what I would suggest. Take it up as high as the trucks floorpan will allow.
10-12-2006, 05:27 PM | #7 |
What if you cut the top off of the drive shaft loop on the stock crossmember to allow your driveshaft to come all the way up, then take your measurement? Or, are you trying not to destroy the stock one? Just a thought.
I'm making my own crossmember (my trailing arms are on the outside of the frame so I don't need the arm mounts) and will have the same problem. I have it mocked up right now and could probably give you a measurement. I'm running a 235 with the stock 3-speed, and a 12-bolt rearend. BTW my chassis is set up to lay frame. Last edited by thekid54; 10-12-2006 at 05:32 PM. |
10-12-2006, 07:29 PM | #8 | |
A guy with a truck
Yep. :yesnod:
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
10-12-2006, 10:14 PM | #9 | |
Señor Member
I'm already up into the cab. I'm trying to avoid the bandwidth required to install, measure, cut, remove, mod, reinstall... since I'm upside down in other projects at the moment If someone could get me a measurement from the center bottom of the xmember to the floorpan, that would help a lot. I think the dip in the center of the stock xmember is about 1" below the rest of the xmember... so I could take that measurement, subtract the 1" (since the ECE unit is flat there), then measure up from the floor to the bottom of the seat. Voila. Digicam is dead, otherwise pics would make this easier for me to explain.
10-12-2006, 11:00 PM | #10 |
XXL-
There are a couple of pics in my dropmember thread that show how much of the floor needs to be removed for driveshaft clearance to lay frame on 29" tall tire. I have more on my computer at work I can get you tomorrow. It isn't much help as for an exact measurement for your x-member, but might be helpful?
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
10-13-2006, 09:17 AM | #11 | |
Señor Member
If I can just get a relationship between the measurement in this pic to the xmember location, I think that would do it. Thanks in advance!
10-13-2006, 01:24 PM | #12 |
A guy with a truck
XXL- I've got 7" from the bottom of the framerail to the bottom of the cab sheetmetal. Maybe 3/8-1/2" difference depending on your body mounts...
10-13-2006, 02:08 PM | #13 | |
Señor Member
Gracias! I'll base my xmember mod from there and porterbuilt's measurements of the cab cuts.
10-13-2006, 05:35 PM | #14 |
WTB this ad
I have the ECE xmember and it touches the cab floor as designed. I don't know if that info helps you any, but I tried!
10-13-2006, 08:10 PM | #15 | |
Señor Member
Thanks.
10-13-2006, 08:53 PM | #16 |
If you go with Porter's numbers you should be fine because his motor and trans is raised 2" due to the Dropmember! Don't forget pic's!
Kevin LFD Inc. |
10-14-2006, 03:23 PM | #17 |
Can you run a 2 piece on a short bed?
1969 Chevy C-10 350/700r4 |
10-14-2006, 03:30 PM | #18 |
WTB this ad
10-14-2006, 03:47 PM | #19 |
Okay thank you for the quick post.
10-17-2006, 04:19 PM | #20 |
well i dont know if you have it in yet but i just picked up my trans crossmember yesterday so i can get my eng and trans mounted this week i will let you know what mesurments i use on my stock hoop this is how it looks right now
http://www.cardomain.com/ride/2461088 |
10-18-2006, 11:00 AM | #21 |
C10 Collector
I brought mine up into the floor and if it still doesn't clear, I'll throw in the 2 piece.
11-15-2006, 04:11 PM | #22 |
Señor Member
I just lopped off the loop on a perfectly good, brand new ECE notch. I'm adding 3" to the top of the loop, and will gusset it as well.
11-18-2006, 09:39 PM | #23 |
Señor Member
A couple of pics from the craptastic phone cam...
11-18-2006, 10:00 PM | #24 |
Cool. Time to cut the floor now . . .....
11-20-2006, 12:30 AM | #25 |
Too many projects
Quick question. From this angle it looks like the brackets are angled the wrong way. Is it me or is there a reason for that?
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
