Junior Member
Bags just on the rear?
I have a 71 Short Fleet and want to do a 4/5 drop. I plan on using drop spindles and 2" lower springs in the front. I want to still be able to tow with it on occasion so if i bagged just the rear what all would I need or should I just get 5" drop springs? The only problem with drop springs was that I didn't know if they would handle trailer weight. I figured if I bagged the rear I could adjust it for the weight. Are 2600 bags enough to handle the weight? Can I just install the bags where the coils are and just hook a compressor and switch up to adjust the weight or do I need a tank and relays and all the other stuff too? I want to do this as cheap as possible.........go figure huh? Please help me out.
Thanks Tim
1967 Chevy/GMC Long Step 350/3 spd on the tree...Old School Lookin for 6-Lug Car rallies. ![]() |
Re: Bags just on the rear?
use the 2,400 - 2,500 lb bag ... you can drill 3 holes and it will bolt right in.
Junior Member
Check out this link and let me know if these bags will work.....
http://www.airbagit-store.com/produc...rch=bagspecial The price looks good to.....4 bags for $118.
#4 | |
On the fast track to nowhere..
i have never used them but i hear alot of complains i would and have stayed away from anithing that has to do with AIM Industries.
1969 Chevy C-10 350/700r4 |
For The Love Of All That Is Good, Stay Away From Anything With The Word AIM In It!!!
Read their add very closely. Notice it says "Dealers Only - all others $69 each." Consider yourself warned. Now, on a more positive note: contact these guys ... they come highly recommended. www.***************** Last edited by Shane; 10-13-2006 at 07:09 PM. |
#7 | |
However.... you can use the F6873 (3150#; 8"dia.; 3"min; 8"max; 5~6" @ ride height) w/o any problems (they will definitely handle the load & are overkill). Use these w/a 2" block & you should need about 40psi of pressure for a decent ride unloaded & then bump it up to 60psi once you need the capacity increased. And yes.... it rides good loaded or not. The above mentioned combo will net about 7" of drop; less if you bump the unloaded air pressure up a little bit.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-13-2006 at 11:52 PM. |
Junior Member
Ok, OK, JUST SAY NO TO AIM!! I get it. Ok, now that we got the bag part handled, what about the compressor switch and gauge deal, is that all I need or do I need a tank and solenoids and all that stuff also? Thanks for the great help so far guys!!
#9 | |
Junior Member
Do I need a C-Notch to lower the rear 5"? I think I read on here you do but just wanted to make sure.
thanks again. Tim
#11 | |
http://www.classicperform.com/Store/...ck/6372CNK.htm The C-Notch is just one of the things you are going to need. Others include an adjustable track bar, lowering blocks, shock relocators, & new shocks. Do a search on this section (Suspension) and you will find answers to most any question you might have. |
Formerly LSC71
To answer your question on the compressor side. No, you don't HAVE to use a compresssor, relay, and tank, but it does make things much easier. Your most economical solution would be to attach a couple of schrader valves and air it up from and external source, but if you are going to be adjusting air pressure on a regular basis you will soon find out how much of a pain that can be. In my opinion you could easily get a small pump w/o a pressure switch that you could activate from the cab and just turn it on and fill (directly into the airsprings) to your desired air pressure. This way takes a little more time but costs less. Just be sure to get a switch that will allow the compressor to fill and deflate the airsprings and also a gauge so that you know what pressure you are running.
