Old 10-17-2006, 12:37 AM   #1
Solver
Solver's Avatar
700-r4 decision
I have a 72 3/4 ton with a 402 engine 400 tranny and 4:10 rear end. I like driving the truck but at 65 mph the thing is turning around 3500 rpm. I have a 700r4 I picked up at a swap meet. Do you think it would be worth it to swap it in. Any ideas what I would be turning for rpms at 60-65 mph.Besides shortening the drive shaft,shifting the tranny cross member,tranny mount and tranny linkage hookup (tv Cable)
what other problems or unexpected pieces am I going to need. Will the current driveshaft bolt up splines wise. Just hate to start the project and be dissappointed with the results or the cost of unanticipated part needs. Thanks
Solver
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 10-17-2006, 12:47 AM   #2
krue
Designated A-hole!
krue's Avatar
Re: 700-r4 decision
The 400 has a yoke while the 700r uses the same splines as the TH350's iirc.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 10-17-2006, 01:08 AM   #3
sweet70beast
sweet70beast's Avatar
Re: 700-r4 decision
I did this same thing in a 72 Gmc 3/4 with a 402 a few years ago. The drive shaft front one will need to be shortened about 2 inches, the trans mount from a th350 will bolt right on the 700, the hardest part about the swap is getting the tv cable hooked up right. The converter will bolt up to the th350 holes in the flexplate.
sweet70beast is offline   Reply With Quote
Old 10-17-2006, 08:24 AM   #4
qksilver
Re: 700-r4 decision
The only concern would be is the can the trans handle the BB especially if you tow with it
qksilver is offline   Reply With Quote
Old 10-17-2006, 02:03 PM   #5
70GMCer
70GMCer's Avatar
Re: 700-r4 decision
I'm going to be doing this same swap. I have did some research on beefing up the 700r4. I have read that you should change the stock servo to a Corvette type and also change the booster to .500 size. From what I have found, these are cheap parts and easy to change. I also plan on changing the converter to around 2000 stall. Here's a parts sight that has the best prices I've found. I haven't bought from them as yet.
http://www.bulkpart.com/Merchant2/me...&Store_Code=2s
You are also going to have to do some lockup converter wiring on this trans.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-17-2006, 03:16 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 700-r4 decision
need to make sure the bellcrank on the carb is of the right diameter and shape, the rate of pull and sensitivity of it needs to be dead on for tranny life. you'll also need a lockup controller too.
Old 10-17-2006, 03:27 PM   #7
Texasdeere
Texasdeere's Avatar
Re: 700-r4 decision
With a 4.10 rear and 29 inch tires about 2160 in 4th with lockup
Your tires are probably a little taller that that though on a C20.
Here is a great gear calculator:
http://www.xse.com/leres/ss/calculator.html
Texasdeere is offline   Reply With Quote
Old 10-17-2006, 04:31 PM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: 700-r4 decision
Here's a site I like. It has a lot of info and a gear ratio chart at the bottom.http://www.transmissioncenter.net/700r4.htm
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-17-2006, 04:39 PM   #9
67ChevyRedneck
67ChevyRedneck's Avatar
Re: 700-r4 decision
I like mine, but I'm on the second one.... as longhornman said... set-up is absolutely CRUCIAL in a 700R4.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-17-2006, 06:11 PM   #10
Werewolf
Woof?
Werewolf's Avatar
Re: 700-r4 decision
Biggest concern is, can a used TH-700 in potentially unknown operating condition stand up long to big block torque? If your engine is more or less stock, it should hold up for a while. As long as you're not abusive towards it. Classically, though, TH-700's just can't be built up as strong as a 350 or 400.
A TH-700's overdrive ratio is .8 to 1. 3500@65 seems awfully high to me, and I don't know that .8:1 ratio is going to bring it down to 2100 @ 65.
1968 LWB CST BB
2004 Avalanche Z71 LT3.
2003 S-10 ZR2 (hers).
1997 Astro
1992 Caprice wagon, 500k stock miles. Nursing wounds after a bad wreck.
1997 Saturn - need gas mileage from something!
Werewolf is offline   Reply With Quote
Old 10-17-2006, 09:33 PM   #11
kwmech
Re: 700-r4 decision
Actually the 700 has overdrive of 28% so the multiplier would be .72--- Your 3500 rpm times .72 would theoretically come down to 2520, without the lock-up. A stronger set-up would be adding on a Gear Vendor unit that has a 22% overdrive.
Old 10-17-2006, 09:38 PM   #12
Texasdeere
Texasdeere's Avatar
Re: 700-r4 decision
TH700R4 4-Speed Automatic Transmission Gear Ratios: 3.06, 1.63, 1.00, 0.70 (1st through 4th)
The overdrive is pretty steep on these.
With the lockup not engaged the rpms will be higher. These trannys can be set up with no lock up or even a hydraulic lockup. (no wires) As everyone has said before proper cable set up is a must. The 700R4 is a good strong tranny but not as strong as the TH400. I would think that a stock big block shouldn't hurt it with normal use. If you pull with your truck just use third gear 1.00:1 for pulling. If you are going big horse power and torque, especially torque a TH400 with a Gear Venders overdrive is the way to go. I think the Gear Vender overdrives are over $2500 .
Sorry, I'll stop now
Old 10-17-2006, 09:39 PM   #13
Texasdeere
Texasdeere's Avatar
Re: 700-r4 decision
You beat me to it kwmech. I just type too slow.
Old 10-18-2006, 07:19 AM   #14
Werewolf
Woof?
Werewolf's Avatar
Re: 700-r4 decision
I could just say I hit the wrong number key, but I won't. Oops! Maybe the 200 had a .8 overdrive. Or maybe I'm just dumb.
1968 LWB CST BB
1997 Astro
Old 10-18-2006, 08:02 AM   #15
67ChevyRedneck
Re: 700-r4 decision
700R4 is .70 to 1 and a 4l60E is .67 to 1.
Jesse James
Project "On a Dime"
