Old 10-17-2006, 04:13 PM   #1
JonnyTechMech
STOP! Hamma time!!!
JonnyTechMech's Avatar
Question 87 front clip conversion
Hi All,
Its been a while since I’ve been on the board. I got a question for you Mod kings.
I’m thinking if replacing the front clip of my 87 GMC with an 88 clip. Parts seem to be getting hard for fine for this model, it always 88 and up in the truck mags. I’ve never seen this nor attempted it yet, but just what parts are replaced? Hood, fenders( inner ), grill and clip for the head lights, what else?
I had an online conversation with BigArms awhile back, but forgot most of it. I just remember he did it to he’s 87. I’m sure there was a significant change from the GM factory from 87 to 88, just trying to cover all bases. I’m pretty sure it can be done.
Any other thoughts or comments would be greatly appreciated. Oh one last thing, how much would one expect to pay for all the clip parts at a junkyard? (How much did you pay?)
JTM
Plan your work and work your plan!!!, or pitty da fool!!
87 GMC BaseTrim, 305 under the wrench/TH400/
92 Chevy 1500, 350,TH700R4 sittin on dubs
JonnyTechMech is offline   Reply With Quote
Old 10-17-2006, 04:51 PM   #2
kevinr1970
Re: 87 front clip conversion
If by '88 you mean '89-91 Suburban and Blazer ('88 still looked like the '87)then you need the core support, harness, grill, headlight bezells, and headlights. Probably a few more smaller pieces.
The inner and outer fenders and hood are the same.
Its only really about a dozen and a half or so bolts - 5 or 6 on eash side to the outer fenders, 3-4 to the front edge of the inner fenders and 2 big ones to the frame horns.
The harness I think is the bigger issue, I haven't installed mine yet. The way the fuse block comes apart is different but I am not sure when it changed. On an '87 you might be lucky and it will bolt right to your fuse block, but I wouldn't count on it. Other than that I guess its a whole lot of cutting and splicing. Tedious but not difficult.
I paid 200 for mine but the same guy about a month later (he parts lots of 'burbs) was offering a complete front clip (inner and out fenders, hood, core support, grill, etc) for $250.
Expect to pay a lot more than that at a wrecking yard. Look for someone parting a 'burb or it might even be worth your while to buy a complete one with a dead engine or tranny. Locally I've seen them go for anywhere from (asking price) $500-$1500.
The guy I bought mine from said he won't pay over $500 for a complete and he has had three or four go through his yard since the spring.
If you only need the grill parts then you might be able to part it a bit and make a little of your money back. If given a choice between a dead engine and a dead tranny I would take the dead tranny. Its harder to show someone the tranny is still god with a dead engine than the other way a around. Also, an engine is a little more universal in its application than a tranny and it should be fuel injected (TBI).
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 10-17-2006, 05:15 PM   #3
edman87
junk collector
I was thinking the same thing, but I believe he means 88-98 c/k style. I have seen it in mags and pics, but not in person. It looks great, but also looks like a lot of work to do it right and make it look like it was supposed to be there from the factory. Good luck and put some pics up.
BTW, a editors k5 in the latest 4wor mag is the most recent 1 I have seen.
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
Old 10-17-2006, 05:21 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
There is a full writeup on going to the 89-91 Burb/Blazer grille here with the part numbers you are wanting...
http://chevy.off-road.com/chevy/arti....jsp?id=275128
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-17-2006, 06:21 PM   #5
JonnyTechMech
STOP! Hamma time!!!
Thanks Captkaos, I just got the site to come up after my sec post. This might be the route I'm looking for. I guess my questions can be disregarded; unless someone wants to answer them for knowledge sake. Best to keep it simple.
JTM
Old 10-17-2006, 07:35 PM   #6
Prerunner1982
Prerunner1982's Avatar
HOWEVER, if you would like the 88-98 (truck) front end and are ok with the idea of fiberglass there are some conversions out there.
http://www.hannemannfiberglass.com/
http://www.glassworksunlimited.com/shop/home.php?cat=9
There are more out there.. but those are the two companies that came to might that should/used to have them.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 10-18-2006, 02:13 PM   #7
kevinr1970
On the hanneman site they listed fenders and hoods for conversion but they don't have pictures. I would be interested to see the how the body lines work.
2000 Tahoe Limited
Old 10-17-2006, 06:09 PM   #8
JonnyTechMech
STOP! Hamma time!!!
Re: 87 front clip conversion to 88-98
Thanks felleas, but let me ask the right question so that I get the right answers.
1. Can the 88-98 model truck,blazer,or burd front end (fenders hood, grill, inside clip for the lights and radiator mount replace theses parts for a 87 GMC/Chevy?
2. If so, is it a complete bolt-up or is welding or mods involved?
Isn’t the hood and the front end a little more pointed on the 88 and up than the 87? Forgive me for the lack of knowledge of part terms. I’m talking more then just replacing the grill and lights.
JTM
Old 10-17-2006, 07:15 PM   #9
Captkaos
Captkaos's Avatar
You question is crossing bodystyles so there isn't a yes or no question. This may help.
Can a 88-91 Suburban, Blazer or Jimmy R10 or V10 front end be swapped to a 81-87 C10 or R10 pickup?
Yes, you only need everything bolted between the front fenders. The hood, fenders and inner fenders are identical.
Can a 88-98 C1500 or K1500 front end be swapped to a 81-87 C10 or R10 pickup?
No. It could with some SERIOUS bodywork and fabrication skills (like 100's of hours). PLUS NONE of the bodylines will line up.
History lesson to hopefully help understanding.
In 1988 the NEW bodystyle of 1/2Ton pickups came out with a completely new design. ONLY 1/2 Tons were availible in this bodystyle.
The OLD R/V series that are actually Identical to the 81-87's were still used until 1991 for Blazers, Jimmy's, Suburbans and ALL 3/4T -up bodies.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 10-20-2006, 10:44 PM   #10
bigblock73
yeller
bigblock73's Avatar
Chris, I thought it was Blazers, Jimmys, Burbs, and crew cabs?? As far as I know, you could get a NBS 3/4 or 1 ton truck back in '88...but not an creb cab in the new body style.
bigblock73 is offline   Reply With Quote
Old 10-17-2006, 07:24 PM   #11
edman87
junk collector
captkaos, don't forget the light 3/4 ton, it followed the switch with new style in 88.
And I might be wrong, but weren't the new body available on 3/4-1 ton in 89 or 90 alongside the old bodystyle?
'91 camaro rs
'98 jeep tj
'52 willys cj3a
Old 10-18-2006, 02:09 PM   #12
kevinr1970
I could be wrong but I thought the only 3/4 and 1 tons that kept the old body through '91 were the crew cabs?
2000 Tahoe Limited
Old 10-20-2006, 10:46 PM   #13
bigblock73
yeller
bigblock73's Avatar
Missed your post...but I think you are right.
Old 10-18-2006, 02:25 PM   #14
84 400
Sb 400 club
84 400's Avatar
I will state for the record i got seat belts out of a 1990 gmc 1 ton with rear wheels it was the rv searies and i thought it was older because it was like a 88 to 91 burb front end. inside it was exactly the same! I am pretty sure he was wanting to out a C/K style nose on his c truck whic i thinkl would be way to much work! if you like that style alot go and buy one as they are getting cheap1 but your best bet is the 88 to 91 burb front end. or find a good front clip from a wrecked one
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 10-18-2006, 06:34 PM   #15
Captkaos
Captkaos's Avatar
I was going to list those prerunner but I figured... nah..
This is the frontend conversion pic from Hannemann Fiberglass.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 10-18-2006, 06:46 PM   #16
Prerunner1982
Those are the exact pics I was going to post before I saw your post...
Jon
Oklahoma Roll Call
Old 10-18-2006, 08:34 PM   #17
bigarmzz
bigarmzz's Avatar
here, check out this link, its goes by the conversion step by step with pictures
http://www.geocities.com/abetterchem...rillchnge.html
i dont know man...i dont personally like the 88-98 front end on our trucks...that fiberglass set up, the fenders look like there pointing downward in the front or sumfin
i personally love the 89-91 front ends on a lowered 2wd truck
jonnytechmech, dont sweat it, the conversion is a piece of cake, if you get a complete rad support, it just bolts right up...its that simple...all ya got to do that might be considered a "little bit" complicated is splicing into your existing wiring....but thats easy peezy too
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 10-19-2006, 10:44 PM   #18
JonnyTechMech
STOP! Hamma time!!!
Thanks BigArmzz, I probably should have PM’d ya, but at least it made for an interesting thread that others could learn from. Now ^….That’s what I’m talking about !!!!!! Not trying to be a total copycat; that’s a hard act to follow anyhow. I didn’t realize that all I was really looking for was an 89-91 front end. I thought it would be more to it like a hood, fender, front end, etc.
I am too… sold on the 89-91 front ends. I didn’t have to give it thought when I went to replace two headlights and the anchors for the adjustment broke, and then the GM dealer ran out of parts for the 87 stock headlight assembly. Long –short it’s time to change out my tired a$$ 87 stock front end; along with the engine.
Thanks to everyone for there comments and help.
JTM.
Old 10-20-2006, 01:52 PM   #19
TATE228
i friend of mine has the 91 gmc jimmy grille and it looks awsome! Its basically the same as the newer body style one but flat. he also has a new style 88 gmc and sitting side by side they look almost the same even though the body style is completly different.
-1971 K20 350/sm465
-2004 1500
TATE228 is offline   Reply With Quote
Old 10-20-2006, 07:35 PM   #20
edman87
junk collector
I will be swapping the front cap from my partsmobile 89 k5 onto my 87 soon. They are getting harder to find every day. Glad I got mine.
'91 camaro rs
'98 jeep tj
'52 willys cj3a
