Old 10-18-2006, 03:03 AM   #1
etg
etg's Avatar
Parts truck?
I have a chance at 500 dollars for a once rebuilt truck that has heavy front end damage. I need a cab for my 69 lwb because mine is toooo rusted. I need to know if since this is a 72 will the cabs swap out? will panels match? What will I have to do to make these two trucks have 1 solid body? I am really diggin this buy.
etg is offline   Reply With Quote
Old 10-18-2006, 03:32 AM   #2
Aarons72s
Re: Parts truck?
The cab wiil swap no problem. But I would like to see some good pics of the driver side. Cause since she hit hard I wander if the cab has ben tweaked. Does the driver side door open and close easily? Do they still line up? If the cab is tweaked it is only good for basic parts. Like the dash, engine trans, rear axle. Just be real sure to look over what you want to use make sure it wasnt damaged.
Aaron
Aarons72s is offline   Reply With Quote
Old 10-18-2006, 08:42 AM   #3
wibilly
wibilly's Avatar
Re: Parts truck?
as aaron said check to be sure doors open and close properly. also look at seat back in realationship to rear window i have one that was hit and you can see the seat appears to be higher on one side than yhe other
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 10-18-2006, 09:19 AM   #4
Yukon Jack
Yukon Jack's Avatar
Re: Parts truck?
Is that a tilt column in there?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-18-2006, 08:51 PM   #5
qksilver
Re: Parts truck?
I have seen trucks not hit as hard that have twisted cabs. The lower front corner of one was so bent they ended up using it for patches
qksilver is offline   Reply With Quote
Old 10-18-2006, 10:14 PM   #6
wibilly
wibilly's Avatar
Re: Parts truck?
check out the floor and cab supports real close
Old 10-18-2006, 10:36 PM   #7
longhorn70gmc
longhorn70gmc's Avatar
Re: Parts truck?
If the cab checks out and the it is also rust free all the way round, go for it. There is alot of guys in San Diego behind the seens looking for parts for these and you should be able to make some money back on some of the parts not used. The Truck swap is in Dec. and you can sell some unwanted parts there.
Good luck and I hope it is what you want and need!!
Respectfully
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 10-19-2006, 04:40 AM   #8
etg
etg's Avatar
Re: Parts truck?
That's what I'm thinking longhorn. However, I will probably end up just taking the front clip off of my truck and using it on this one because this one just is in better condition. I already told him I will take it. Yay
