411 Gear?
The numbers on my 12 bolt ring gear say 11-41 GM. Can't read the pinion gear. Is this a 411 gear rear?
1997 GMC Sierra Ext 1965 Mustang |
Living In The Past
Re: 411 Gear?
I really dont know but I will take a guess. 11 is the pinion tooth count and 41 is the ring gear count. 41 divided by 11 = 3.727. rounded off = 3.73
Count the teeth and divide and know for sure Last edited by Olden Days; 10-21-2006 at 01:48 PM. |
sufficiently talented fool
![]() Join Date: Jun 2006
Re: 411 Gear?
I believe that is correct.
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
![]() Join Date: Mar 2003
Re: 411 Gear?
It is correct---divide the ring by the pinion
The Older Generation
Re: 411 Gear?
This may have been posted before.....
![]() Ratio 2.56:1 Tooth Combination 41,16 Ratio 2.73:1 Tooth Combination 41,15 Ratio 3.07:1 Tooth Combination 43,14 Ratio 3.08:1 Tooth Combination 40,13 Ratio 3.08:1 Tooth Combination 37,12 Ratio 3.31:1 Tooth Combination 43,13 Ratio 3.36:1 Tooth Combination 37,11 Ratio 3.42:1 Tooth Combination 41,12 Ratio 3.55:1 Tooth Combination 39,11 Ratio 3.73:1 Tooth Combination 41,11 Ratio 4.10:1 Tooth Combination 41,10 Ratio 4.11:1 Tooth Combination 37,9 LockDoc .
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 10-21-2006 at 08:35 PM. |
Re: 411 Gear?
This is also very good info from LOCK DOC.
First the key/lock data and now this. You gotta love the board - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
Re: 411 Gear?
Thanks for the info......kinda glad it isn't a 410......A 373 with a planned 700r4 will work just fine.......
steve
