Old 10-29-2006, 04:37 PM   #1
JTK20
Active Member
4x4 shifting question
This may be a dumb question, but is there anything specific you have to do to shift a truck in 4wd-Low? I just bought an 85 3/4 ton and yesterday when I was test driving it I couldn't shift the t-case into N or 4L, but it goes into 4H just fine. Not sure if you have to be in a certain gear or something first. Thanks!
-Jason
JTK20 is offline   Reply With Quote
Old 10-29-2006, 04:56 PM   #2
msgross
msgross's Avatar
Re: 4x4 shifting question
I have only used 4 low only a few times ever, it's great for tons of power for pulling something out of a ditch or going up a very steep hill in the woods. You have to be in Neutral on the transmission to place the Transfer Case in or out of 4Lo, you have to be stopped as well. Remember to never use either 4WD on dry pavement and be careful with tight turns, easy way to tear up your powertrain.
msgross is offline   Reply With Quote
Old 10-29-2006, 06:18 PM   #3
trixter99
I have no time for this
trixter99's Avatar
You might want to put the trans in nuetral as well it will make shifting alot easier, also it wont go intp 4low if you are moving.
1986 Chevy short box ( PROJECT )
1994 Chevy Blazer lifted 6"
2009 Gmc 2500 HD
1999 Hugger orange Camaro SS
2007 BMW X5 Sport
trixter99 is offline   Reply With Quote
Old 10-29-2006, 06:36 PM   #4
JTK20
Active Member
Yeah there's no way I'd try shifting into 4L while it's moving. That'd make for a bad day. When I tried shifting it in I was on dry pavement (just wanted to see if it would go in), stopped, and I tried it while in gear, in park, and in neutral and I couldn't get the shifter to go past 4H. Could it be because (and I just realized this) I didn't lock out the front hubs first? I didn't think that had anything to do with the t-case shifting in and out of 4wd, but this is my first 4x4 so I don't know for sure.
-Jason
Old 10-29-2006, 09:10 PM   #5
bad_turbo
turbo enthusiast
bad_turbo's Avatar
front hubs shouldn't have anything to do with the T-case shifting
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 10-30-2006, 06:44 PM   #6
Bender
That’s exactly what I would think, but my truck will not go into 4 low without the hubs locked in?
And when I get it in 4 low, I can’t unlock the hubs
(I’ve owned this truck for 21 years now, and I’ve had it in 4 low hundreds of times, I just thought that’s the was the way the truck is?)
Bender is offline   Reply With Quote
Old 10-29-2006, 09:21 PM   #7
BJA69C10
BJA69C10's Avatar
you probably would've noticed this, but i've several trucks, including a 95 ford and a 91 chevy that require you to push down on the shifter in order to shift into nuetral or 4low. hope you figure it out
'69 C10 350/3spd dropped 3/5, 93 Stepside bed...was my highschool project, but now it's gone to college with me
BJA69C10 is offline   Reply With Quote
Old 10-29-2006, 09:21 PM   #8
edman87
junk collector
Totally stopped and in neutral to get to 4lo. If it won't go and the t-case is a np208, a shifter fork is prolly worn. If it slips from 2hi to N, shifter fork definately worn/ damaged, very common on the np208. Your 3/4 ton migh or might not have this.
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
Old 10-29-2006, 09:45 PM   #9
Southedisto
River life......
Southedisto's Avatar
1st : did you move the shifter laterally while pulling it into 4lo?
2nd : try shutting the engine off and pulling it into 4lo
Southedisto is offline   Reply With Quote
Old 10-29-2006, 09:50 PM   #10
msgross
msgross's Avatar
Might be to late for this one, but always test the 4WD system when buying a truck. If for some reason you can't figure it out i wouldn't sweat it. Once 2HI or 4HI goes bad then you have issues.
Old 10-30-2006, 01:44 AM   #11
JTK20
Active Member
I did try pulling and pushing down on the shifter to see if that would help, but that didn't work. I didn't try moving the shifter laterally though. Anyway, I'm not too worried about it since it goes into 4H just fine. A friend of mine who has an 82 said his t-case is just as stubborn trying to get into 4L.
I just brought it home tonight (drove it 2 hours back) and I was impressed with how well it drives. It's fugly though, that's for sure.
Old 10-30-2006, 04:26 PM   #12
Billy81
Billy81's Avatar
The way it works on my 86 blazer with a NP208 the transmission has to be in neutral and when you go to shift the transfercase you have to be quick. You cannot stop or pause while you are shifting or it will not go into neutral or 4lo.
Billy81 is offline   Reply With Quote
