10-30-2006, 06:21 PM | #1 |
Life, Be In It.....
What is this part called?
I have two question;
(1) I'm planning on using a 9" or smaller power booster. The ones I have seen do not have the eye hole part attached. What is it called and where can I get one. (2) I would like to use the original booster to firewall brackets. Any suggestions on which after market booster that will work with the OEM brackets. Thanks I apologize for using someone elses pic
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
10-30-2006, 07:39 PM | #2 |
'69 Step
Re: What is this part called?
Power brake booster pushrod?
10-30-2006, 07:49 PM | #3 |
sounds good to me
1970 Chevy C10 "Under Construction" 2002 Chevy S10 V6 |
10-30-2006, 09:23 PM | #4 |
Life, Be In It.....
I guess I should be a little more specific. The piece on the end with a hole through one end and the nut on the other. The piece attached to the push rod, the shinnier aluminum looking piece. I did not researched and think it is called a CLEVIS, where can I get just the CLEVIS?
10-30-2006, 10:11 PM | #5 |
I don't know where to buy a new clevis but try the board for a used rod and remove the clevis. I don't know how you are mounting your new booster but as you can see the 67/72 style uses a fulcrum to change the leverage. The 67/72 style boosters have a non-adjustable rod attached and the adjustment comes from the bracket to pedal portion. Sorry that's not clearer.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
10-30-2006, 10:44 PM | #6 | |
Life, Be In It.....
Bob, you have answered some question I had, but I'm confused about something. My brake pedel bracket (pictured) came off my truck and had all the attached pieces on it when I removed it from the truck. The push rod on the brake pedel bracket comes to a point. Also pictured is the booster and booster bracket (pictured) I got from a wrecking yard. Here is my question; how do they connect to eack other? Or do I have two different styles?
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 Last edited by jugernot; 10-30-2006 at 10:46 PM. |
10-30-2006, 10:58 PM | #7 |
GO TO NAPA & ASK THEM FOR A HEIM-JOINT. THEY'RE ABOUT $5. BEEN THERE-DONE THAT. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
10-30-2006, 09:55 PM | #8 |
if your truck currently has brakes it should have one. both power and non power brakes have the same "clevis". if you need one let me know i have an extra.
10-30-2006, 10:16 PM | #9 |
check out www.mpbrakes.com, they have re-vamped there website, totally un-user friendly, but request a catalog via snail mail, they should have what your looking for.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
10-30-2006, 11:03 PM | #10 |
taken care of.
10-30-2006, 11:22 PM | #11 |
Jugurnot - The brake pedal you removed from your truck was it manual or power? Looks like manual - direct to the mastercylinder. Only the power brakes have the fulcrum setup.
10-30-2006, 11:34 PM | #12 | |
Life, Be In It.....
Bob, Now that you mention it, the cab did have manual brakes on it. So what do I need to convert the manual brake pedel setup to a power brake set up?
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 Last edited by jugernot; 10-30-2006 at 11:35 PM. |
10-30-2006, 11:41 PM | #13 |
Get a power brake push rod. Should have a hole on one end (fulcrum) and the clevis on the other(brake pedal).
What is on the end of the rod coming off the fulcrum now?
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow Last edited by Bob Moore; 10-30-2006 at 11:44 PM. |
10-30-2006, 11:47 PM | #14 | |
Life, Be In It.....
Thanks for the lesson.
10-30-2006, 11:53 PM | #15 |
Life, Be In It.....
10-31-2006, 09:15 AM | #16 |
Is anyone else running power brakes, but without the intermediate linkage? In other words, the two eye holes (the rod from the pedal & the rod from the booster) are bolted directly to eachother?
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
