10-30-2006, 07:42 PM | #1 |
No dash lights or taillights and parking lights
This morning I went out to go to work and my 71 gmc had no dash lights or tail lights or parking lights. I check the fuse under the dash and it was ok. Where should I go to next?
10-30-2006, 07:54 PM | #2 |
Re: No dash lights or taillights and parking lights
May be a ground issue or maybe the headlight switch itself...........Joe
10-30-2006, 07:55 PM | #3 |
all the power for these runs through the light switch. check the connections there.
1966 Chevrolet Suburban 1955 Chevrolet Bel Air |
10-30-2006, 08:04 PM | #4 |
its all about the +6 inches
brake lights don't go through the headlight switch.
Did you test that fuse, or just look at it? They can blow clear up at the end and you can't see it. You defenatly have a power problem, those all run off that one fuse. |
10-30-2006, 08:30 PM | #5 |
I check the fuse its ok, the headlights work fine.
10-30-2006, 08:32 PM | #6 |
time to get the test light and find out where you stop getting power. I suspect it'll be close to the fuse box being that it branches out afterwards.
10-31-2006, 02:12 AM | #7 |
10-30-2006, 11:51 PM | #8 |
Chief Honcho In Charge
He said he had no tail lights (running lights I expect)...not brake lights. Parking lights being those side marker lights, or the front amber lights.
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
10-31-2006, 03:08 PM | #9 |
Buck, do your brake lights work?
10-31-2006, 07:23 PM | #10 |
since you say the headlights are working you must have power to the switch. i would bet there is a bad connection at the switch.
11-01-2006, 09:05 AM | #11 |
longhorn, I have no brake lights.
11-01-2006, 03:57 PM | #12 |
OK, start at the fuse box, looking for power. remove the fuse, and make sure the holders are not corroded/rusted. You'll probably shatter the fuse removing it, so have glasses on, and have a spare fuse in your pocket.
I am 99% positive your problem is in that area since everything on that circuit is dead...and assumingly all at once. |
11-02-2006, 02:50 PM | #13 |
It was the fuse, I look at the wrong one the first day.
Tks guys. |
