cluster redo
I am going to start buying my guages for my dash redo. I am going with autometer phantom guages mainly because I like white and they still have 3 3/8 availible. A few questions The gas guage is 0-90 ohms correct? And the speedo I would like to go mech for cost reasons how do I know if they will fit with our speedo calbe or will I need to purchase a new cable or adapter? Is there anything else about the speedo or any other guage I need to know? I am going with speedo and tach, water temp, oil pressure, volt, fuel level and vac.
Thanks for any tips.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
Re: cluster redo
The gas gauge is 0-90ohmsThe mechanical speedo will work with your cable. The other thing you need to decide is if the other gauges will be electric or mechanical.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Re: cluster redo
I am leaning toward mech I have always thought them to be more accurate. I have a small cheap three guage deal under the dash now with mech oil and temp and they seem to work fine.
![]() Join Date: Feb 2000
Re: cluster redo
The above info is correct. Here is a pic of the Phantom gauges that I am using
![]() I did swap the tach and speedo position as the speedo is supposed to be on the left side. Forget that when I initially installed the gauges. You will definitely like them.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Re: cluster redo
Yukon was the mod fairly easy? Looks good did you like the phantoms?
![]() Join Date: Feb 2001
Re: cluster redo
As per my PM. These are the ones I have.
Re: cluster redo
I would be interested in the water temp one 5839 how much for it?
Re: cluster redo
Won't let this become a for sale thread. PM sent.
Re: cluster redo
Glad Mudder has seen this post - he helped talk me through the wiring when I was doing my project. Although I have PM'd you this pic, I thought I would post it here for others who are reading your post.
Re: cluster redo
Another question? The brake warning light did most you hook it up or no? Do I just need another led for it then wire it to the signal wire?
Re: cluster redo
You can wire whatever lights etc up by just finding the the right wire in the old harness that you will be diconnecting. There is a diagram that shows the wires and the colors. It may vary a little in the colors but works real well for finding the turn signals and high beam etc.
Re: cluster redo
Thanks. Will do that then.
Re: cluster redo
If you hook up an LED where a lightbulb once was you may need a resistor in line with it. When I did mine I had a slight draw when the light was off and it was just enough to light the LED. I put a resistor in line and it fixed the problem.
Re: cluster redo
where is the diagram for the wiring if changing to aftermarket gauges????
#15 |
Re: cluster redo
Not to take this off on another direction I tryed to make my brake light go on. With e-brake on nothing pulled sending wire off prop valve nothing what makes these things come on? It comes on when I start her momentarly like it should?
#16 |
Questionable
Re: cluster redo
Brake light normally came on with mine if I was starting OR if the brake fluid was low.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#17 |
Re: cluster redo
ok so only when starting or fluid was low.
#18 |
Re: cluster redo
Will SW gauges work dsame as d autenmeters with us trucks we has????
