Old 10-31-2006, 12:02 PM   #1
pkj
shock relocaters
started putting the bags in last night with brackets i made. all fits nice. i already removed the shock brackets before painting frame. question is can i reuse these by adding or making a bracket? has anyone done this and what are the specs? funner to make somethings then just buy them. thanks, pkj
pkj is offline   Reply With Quote
Old 10-31-2006, 03:00 PM   #2
roj2323
Re: shock relocaters
front or rear? what type of truck ? these are important to answer your question. pictures are allways cool too.
ondrew
roj2323 is offline   Reply With Quote
Old 10-31-2006, 03:56 PM   #3
pkj
guess my head is not on right today. 68 1/2 ton, rear. i know i can buy them, but would like to see if anybody has fashioned a way to relocate the original ones. thanks, pkj
Old 10-31-2006, 04:06 PM   #4
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
You can reuse the lower rear ones, simply flatten out the edges (torch and hammer) and flip side to side. This worked on mine and I'm pretty satisfied with the ride.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 10-31-2006, 09:42 PM   #5
see ten
WTB this ad
see ten's Avatar
Yep, Early Classic used to provide a shim so you didn't have to flatten them out. They can be flipped upside down and swapped from the drivers side to the passenger side.
see ten is offline   Reply With Quote
Old 11-01-2006, 07:49 AM   #6
pkj
i am confused. i thought it was the top brackets that you change when you lower truck? i already cut the rivets and removed these prior to paint. please get me on the straight and narrow. thanks, pkj
Old 11-01-2006, 01:44 PM   #7
lowrollin70gmc
Too many projects
I guess you could also turn the top brackets around (as they are asymetrical) to get your shock to stand up better. I would align them so the shock is more of a vertical position, hence more effective. Also, you could still flip the bottom ones, as it puts the shock mount lower in relation to the axle.
Just for my curiosity, how low is your axle (or high in relation to the frame) going to be? What size notch are you using/not using? Mine's bagged w/o a notch and I was thinking about putting a bolt in notch in (came with bags)?
Pictures of your brackets, both for the shocks and the bags would be helpful for my personal uses (redesigning my own truck).
Andrew
Old 10-31-2006, 04:58 PM   #8
jimmydean
jimmydean's Avatar
I got them free with my shocks, so I didn't worry about it.
jimmydean is offline   Reply With Quote
