Alright Alright Alright
head bolts and pushrods for vortec heads
i am building a vortec headed 350 and i was wondering what head bolts an pushrods i should use. will regular pushrods and headbolts that fit a 87-95 tbi motors work? (its going on a 89 350)
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
Too many projects!!!
Re: head bolts and pushrods for vortec heads
When I built my 355, with Vortec heads. I used a set of stock length pushrods used on any standard sbc, I did get hardend ones though.
I also used standard head bolts...the only difference in the vortec heads really, is the internal design of the head..and you will have to use self alinging rockers.
Sean ![]() 1995 Buick Roadmaster Sedan 2004 Chevy Trailblazer 5.3L V8 1963 Chevy Biscayne 4D Sedan 1971 Chevy C10 (now have 70 cab & frame) 1968 Chevy C10 (parts for the 70) 1991 Oldsmobile Custom Cruiser (Chevy 355 motor) 1937 Pontiac 8 4D Touring Sedan (in pieces) Jacksonville, Florida |
The head bolts and push rods are the same as any other SBC. You can use your old ones if they are in good condition.
Tim |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
![]() Join Date: Mar 2000
The head bolts will work fine and so will the pushrods if you be sure to use self-aligning rockers though as standard rockers will dance sideways on ya and pushrod will end up bent, if you don't use self-aligning rockers then you will need to have heads drilled for guide plates and use harded pushrods.
I use the pro-form self-aligning roller rockers from Summit, great price coupled with a great performing rocker on needle bearings, you can buy the GM self-aligning rockers that are stamped steel and look like stock rockers but the price is esstentially the same as roller rockers so in my book rollers are the way to go. GMCPaul |
