![]() Join Date: Jul 2004
Door glass rubbers and felts that fit ???
Where can I get door glass rubbers and felts that sit on the top of the door by the glass that fit ? I got some from the same place (LMC) I got some from about 2 years ago and the design has changed. The outside pieces have rib molded at the bottom on the inside and it hits and catches on the metal under the window when rolled fully up, can't trim it very much there is metal ridge under the rubber bump.
The inside felts have this sticky tar-like crap on there backs, I can deal with that but it seems the metal prongs stapled in the felt are too big and catch the metal bottom of the window also. Just wasted 30 bucks on these, so now I need to get some that actually fit. Anyone have any suggestions, what have you recently used ? Thanks.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 11-12-2006 at 10:03 PM. |
Re: Door glass rubbers and felts that fit ???
Man that sucks big green. I have bought mine from kennys and lmc and have not had any problems yet. I would check with gmcpauls he could probably help. I wander if they gave you the wrong ones?
Aaron www.gmcpauls.com |
![]() Join Date: May 2006
I've used a product called people's choice repops, they fit exactly as original, although I have a Jimmy and no top seal. I was amazed how nice they were. My only problem was, they came with a piece of white foam matrl. and I can't figure out were that is supposed to go, it's still sitting on my work bench! J
jaros44 how much white foam stuff did you get? was it for the seal between the door and interior door panel? my weatherstrip is from Presion, i haven't installed any yet so i don't have an opinnion yet
common sense isn't so common anymore |
[QUOTE=wibilly;1864030]jaros44 how much white foam stuff did you get? was it for the seal between the door and interior door panel?
Not sure what it is for,it was about 2 feet long, about the lenght of the fuzzy strip and rubber strip that hold the window from rattling in the door. It is also perforated so you can tear sections off neatly. It has been in both of my kits, but who knows..... J.
The Hammer Man
![]() Join Date: Oct 2006
thats styrafoam packing to protect your felt j/k
If you didn't write j/k. I would have believed you, I have no idear what their for.. J.
![]() Join Date: Jul 2005
Got mine from LMC they fit very well...
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
Has anyone used the kits from Classic Industries?
Thanks, Mike |
![]() Join Date: Aug 2005
Yes, I got a set from Classic Industries and they were the Peoples Choice brand that the above post mentions. They fit well, though they were slightly too long and I had to trim them a bit. Better too much than not enough!
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
Brothers > LMC IMHO
I've ordered some from both Brothers and LMC. LMC ones had wimpy clips, and both sets needed trimming on the edges. I didn't notice a ridge interfering with the window. Mine look like this... little blurry but you get the idea:
I agree all I have used are too long. I just trim them with a pair of bolt cutters. Works good and looks the same as factory cuts.
Aaron |
