Old 11-05-2006, 02:08 PM   #1
Blizz
Blizz's Avatar
welding in floor pans...
with a mig....gas or gasless?
'72 K5 CST Blazer 4x4 in perpetual progress
'96 2dr Tahoe 4x4 daily driver, Black Bear Performance tune, 285-75-16 Nitto Grapplers, Magnaflow muffler, K&N Air filter, Bilstein Shocks.........E-fan, DT Tri Y or Pacesetter LTs coming soon
Blizz is offline   Reply With Quote
Old 11-05-2006, 02:09 PM   #2
71swb4x4
71swb4x4's Avatar
Re: welding in floor pans...
I have always thought MIG/gas was the easiest to work with.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 11-05-2006, 02:35 PM   #3
72CSTC5
72CSTC5's Avatar
mig with gas, the easiest by far.
72CSTC5 is offline   Reply With Quote
Old 11-05-2006, 02:37 PM   #4
krue
Designated A-hole!
krue's Avatar
Cleaner welds by far.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 11-05-2006, 05:07 PM   #5
vtblazer
vtblazer's Avatar
Yep, all the above.
vtblazer is offline   Reply With Quote
Old 11-05-2006, 07:49 PM   #6
71swb4x4
71swb4x4's Avatar
I assume you are welding inside. If you are outside and there is a breeze then gasless is the way to go.
Old 11-05-2006, 08:19 PM   #7
Blizz
Blizz's Avatar
i was sold on gas until the last post. so why gas or why not gas? i don't have any tanks right now so i'd have to buy one and the gas. i can weld inside or outside.
Old 11-05-2006, 10:18 PM   #8
71swb4x4
71swb4x4's Avatar
If it's windy the shielding gas can blow away and then you will have a terrible time welding. By far the best scenario is inside with gas. If you have to weld outside in wind I would use gasless. I welded with gasless first, and once I picked up the gas it was amazing how easy it was to lay a good bead.
Old 11-06-2006, 10:07 AM   #9
raggedjim
raggedjim's Avatar
If you're like me, when you bought your welder you got some free flux-core. I used that to put in my floor pans. It was free (kinda) and the welds would never be seen.
I bought .023 esab ezgrind and a bottle for the exterior body work, but I figured why use the $$$tuff on things that wouldn't be seen.
The gas and thinner wire is easier but you can do it with the flux-core.
jmho, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 11-07-2006, 11:33 PM   #10
WORNBRAKES
You get a lot of spatter with flux and it is a pain to clean up. I would use gas and do short lines so the metal dont overheat or warp.
Mario and Mandy
Hughesville, MD 20637
69 C10 305/350
71 K5 Basket case
75 K10 Rescue **Parting out**
77 MG Midget **Parting out**
15 6.7L Cummins
WORNBRAKES is offline   Reply With Quote
Old 05-22-2007, 04:32 AM   #11
DURRTY
USMC
DURRTY's Avatar
When welding MIG (with gas and hard wire) you do have to be careful of wind and also the metal needs to be clean. Any rust, old paint, durt ETC will cause the weld to have porosity and incomplete fusion. Use a wire wheel on your grinder and clean it as best as you can. If there is rust that goes deep and wont clean off with the wire wheel, MIG wont do it, yes it might stick it together but you cant get a good weld.
The flux core wire(gas less) rules when it comes to durrty metal. You should still clean it but it wil burn through the paint and rust pretty well.
For the spatter there is some help out there. There are products called anti-spatter that you spray on before you weld. It makes the clean up much easier.
MIG looks good but looks don't mean that its a good weld.
If you can have both types of wire around (and some gas) you cant go wrong.
Semper Fi
DURRTY is offline   Reply With Quote
Old 05-24-2007, 12:27 AM   #12
BLUE THUNDER
BLUE THUNDER's Avatar
i'm ready to help out blizz. let me know when and we'll have a work day.
BLUE THUNDER is offline   Reply With Quote
