Old 11-06-2006, 12:04 AM   #1
shifty
Questionable
shifty's Avatar
Question Feedback from those using Ididit or Flaming River column
Specifically want to hear from people using one in their 67-72 truck. How easy was installation? Any words of advice/experience that would be helpful?
I am buying one or the other at this point - was thinking about doing a tilt/telescopic one. Just curious to hear from others who are using one in their trucks...and wanted to get all this ironed out BEFORE buying and installing mine.
Thanks. (Pics of installs are always welcome!)
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 11-06-2006, 12:11 AM   #2
tom71
what happened to flint mi
tom71's Avatar
Re: Feedback from those using Ididit or Flaming River column
i went with ididit before i started the frame off. chrome, tilt, telescoping, came with the correct adapter for the wiring harness. it was a plug and play situation and took about 2 hrs to install in a running truck . i would buy one again . ive heard good things about the flaming river one too, i dont think you can lose either way . tom
71 swb 2wd fleet frame off in progress
72 4x4 blazer daily driver
70 olds cutlass s mint condition owned by a grandma
56 gmc 2wd project waitng
97 fiance mobile
tom71 is offline   Reply With Quote
Old 11-06-2006, 12:15 AM   #3
shifty
Questionable
shifty's Avatar
I think I'm gonna go unpainted and paint it myself. You have a '71 so your e-brake setup isn't the same as mine ... My big questions right now is how much of the stock hardware is required for the install, and whether it is a direct bolt-up replacement. There are like ... 2 straps on the inside and 1 weird looking thing that strapped to the firewall side and had two bolts holding it in - was curious if that was also used with a FR or Ididit column.
Thanks for the feedback so far.
Old 11-06-2006, 12:41 PM   #4
shifty
Questionable
shifty's Avatar
*bump*
Old 11-06-2006, 01:04 PM   #5
1LoC10
Insert Title Here
1LoC10's Avatar
Not sure if they have different models, but a friend of mine had a flaming river about 5 years ago and it was just plastic with a chrome shell around, and he wasnt happy with it
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 11-06-2006, 02:32 PM   #6
sleepyboy
'69 Step
I like my flaming river I bought from Summit. Easy install. I did get a narrower shaft though so I needed to change the bottom seal.
sleepyboy is offline   Reply With Quote
Old 11-06-2006, 05:37 PM   #7
kylejamers
ididit
kylejamers is offline   Reply With Quote
Old 11-06-2006, 11:00 PM   #8
gregfull
gregfull's Avatar
shifty, here's a link to a thread I started a while back. I still haven't bought mine yet. Hope this helps. http://67-72chevytrucks.com/vboard/s...d.php?t=181698
My Suburban Project
72 Suburban
68 SWB
57 Belair
55 Cameo
06 Chevy 1/2 ton crew
09 Suburban
gregfull is offline   Reply With Quote
Old 11-06-2006, 11:16 PM   #9
shifty
Questionable
shifty's Avatar
Hehe, thanks Gregfull. I actually started a similar thread or at least asked Greasemonkey how he did his stuff a long time ago also, he told me, but I can't seem to find the thread. Will need to do that later.
I'm going to get tempted when I go to Summit superstore tomorrow, and I will probably end up buying one of the damned things, but ... we'll see if I can resist temptation. I was actually surprised at the price while I was there last time. With the setup like greasemonkey has, it's gonna set me back around $400. More money sunk into the pit
Old 11-06-2006, 11:50 PM   #10
68 short step
400 for the ujoints and intermittion shaft?
if so thats not a bad deal at all!
68 short step is offline   Reply With Quote
Old 11-07-2006, 01:56 PM   #11
gregfull
gregfull's Avatar
A Summit Superstore?????? I'm glad there's not one of those near me, I'd be broke and divorced. HA HA.
My Suburban Project
72 Suburban
68 SWB
57 Belair
55 Cameo
09 Suburban
Old 11-07-2006, 02:11 PM   #12
shifty
Questionable
shifty's Avatar
My Amex bill was $1800 last month. I'm not married yet, but she still loves me, even seeing stuff like this, so I think I got me a keeper
Old 11-06-2006, 11:52 PM   #13
68 short step
also are you going with a 35" one or a 33" one ( for added chest to wheel clearence?)
Old 11-07-2006, 12:06 AM   #14
shifty
Questionable
shifty's Avatar
I am still not sure yet on that one. I am still working on the cooling system and need to buy some fans. Want to buy a barely used setup of LS1/LT1 fans? (I'm gonna hafta find something else to use w/this new fan mounting plate!)
Old 11-07-2006, 11:49 AM   #15
greasemonkey
greasemonkey's Avatar
Hi again Shifty,
I couldn't remember all the different components by now, so I went and found the PM I sent you with the part numbers. The part numbers should still be good.
I bought the parts for the intermediate shaft from Summit racing. The shaft from the column is a 1" DD shaft, the intermediate shaft is 3/4" DD, and the steering box is 3/4" 36 spline. So you need two ujoints: 1" DD to 3/4" DD, and 3/4" DD to 3/4" 36 spline. I used one Flaming River ujoint, Summit part # FLA-FR2517DD and one Borgeson joint BRG-013449; I used the Borgeson because the Flaming River joint of 3/4" to 3/4" 36 spline did not fit on my steering box splines (it was just too tight for some reason, and I didn't want to force it). The shaft was a Flaming River FLA-FR1850, you just cut it to fit. The ujoints are a simple bolt on, no welding needed.
Hope this helps,
John
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 11-07-2006, 01:16 PM   #16
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Flaming River columns are "stainless" and much better quality inside & out...there is no plastic or anything like that. Their columns are designed after our truck style columns, so they look much better in our trucks! Period.
I almost always have one made up and ready to go for our trucks, specifically...in stock...polished/chrome & brushed.
PICKMUP is offline   Reply With Quote
Old 11-07-2006, 01:36 PM   #17
68 short step
got my attention... what do ya get for either of them?
Old 11-07-2006, 07:14 PM   #18
lost wages
lost wages's Avatar
i bought my column from pickmup, really nice finish and fit.
lost wages is offline   Reply With Quote
