Old 11-10-2006, 12:42 AM   #1
Slammed70
Slammed70's Avatar
Camaro died....
My Z breaks down all the time and its gotten to the point where I just dony want to fix it anymore, so check this out....
Im thinking about ripping the T56 out and throwing it in my 70SWB. My trucks a factory three-on-tree (now a TH350) and I still have the clutch pedal. I was wondering if theres a way to use the factory clutch pedal with the Camaros hydraulic style system?
Thanks,
Mitch
Slammed70 is offline   Reply With Quote
Old 11-10-2006, 01:07 AM   #2
ghetto_superman
ghetto_superman's Avatar
Re: Camaro died....
this guy is putting a hydraulic clutch in his truck.. maybe it will help you out.
http://67-72chevytrucks.com/vboard/s...draulic+clutch
ghetto_superman is offline   Reply With Quote
Old 11-10-2006, 01:26 AM   #3
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Re: Camaro died....
Just keep in mind those tranny can't take the abuse too good, I'm going on the 2nd tranny behind a very healthy 350 in my sonoma in 2 years, but is sure fun driving it!
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 11-10-2006, 07:51 AM   #4
Jim_PA
Re: Camaro died....
T56's are advertised at taking up to 400 ft/lbs of torque. I think you're biggest issue will be the speedometer, but if you do a google search for t56 conversion, you will find all the info you need.
Jim_PA is offline   Reply With Quote
Old 11-10-2006, 11:02 AM   #5
BarryB
BarryB's Avatar
Re: Camaro died....
Hey I put one in My 74 Nova. All I did was change around my crossmember, and fit it to my old aluminum bell housing. So I could use my old clutch linkage. I believe I had to have my drive line shortened. But it has been awhile ago since I done that. I ended up ripping it out and i put an auto back in. But it was fun while I had it in there.
BarryB is offline   Reply With Quote
Old 11-10-2006, 02:28 PM   #6
Jim_PA
Re: Camaro died....
I think people are confusing T5's and T56's in this thread. A T5 is from the 82-92 Camaros -- T56's are the 6 speed trans from 93 and up camaros, corvettes, dodge vipers, etc, and require some work to drop in an older chevy.
Old 11-10-2006, 03:57 PM   #7
shifty
Questionable
shifty's Avatar
Re: Camaro died....
Good luck! I'm in the process of setting up a T56. Almost have the bracket done (see page 7 of the ls1tech thread in my signature). Just sending it off for fabbing once I draw it up in autocad....
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 11-10-2006, 05:31 PM   #8
Deuce
Deuce's Avatar
Re: Camaro died....
Is the camaro TPI?? Wanna sell the TPI set-up if it is??
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 11-10-2006, 11:02 PM   #9
Slammed70
Slammed70's Avatar
Re: Camaro died....
No, its the LT1.....Im not to up to par with the 3rd gens but I think the TPIs are 85-92, The LT1s are (92 Vette)93-97 4th gens...then 98-02 its the LS1.
Old 11-10-2006, 11:23 PM   #10
blacktruck
Super Trucker
Re: Camaro died....
i think you need an adapter plate to mount the t-56 to a gen I sbc bellhousing. measure the input shaft. i think the t-56 is longer. the LT1 t56 is supposedly easier to use with a gen I because of the clutch. check out some of the camaro message boards. it's kinda common to retrofit a t-56 into a 3rd gen. good luck. i've forgotten a lot about this swap.
American by birth, Southern by the grace of God.
".. you aint just whistlin' Dixie..."
Rebel till I die
blacktruck is offline   Reply With Quote
Old 11-11-2006, 12:05 AM   #11
Slammed70
Slammed70's Avatar
Re: Camaro died....
Hmmm, I think I might of forgotten to mention....but my Camaro Im ripping this out of is a 95 LT1(now LT4) powered Z28.
Old 11-11-2006, 01:38 AM   #12
Musclerodz
Re: Camaro died....
LT1 T56's will bolt up to any Gen I or Gen II SB Chevy. LSx T56's require an adapter plate.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 11-11-2006, 02:04 AM   #13
blacktruck
Super Trucker
Re: Camaro died....
Mike
i've forgotten a LOT about this whole t56 thing.
Rebel till I die
Old 10-09-2007, 01:47 AM   #14
ColinOpseth
Re: Camaro died....
Mike
Yes, but you can't run a 454 with the Centerforce flywheel because it's externally balanced. Largest you can run is 427 (internal balance). Centerforce part number is 700107.
Webmaster: www.h-body.org
ColinOpseth is offline   Reply With Quote
Old 11-11-2006, 02:23 PM   #15
Deuce
Deuce's Avatar
Re: Camaro died....
Want to sell the fuel injection??
Old 11-12-2006, 09:48 PM   #16
Slammed70
Slammed70's Avatar
Re: Camaro died....
I doubt it'll work on anything non-gen II.
Unlike conventional FI set ups, it uses a cam sync/crank trigger in the form of a peice of **** called an "Optispark" to tell the injectors when to open.
So unless you want the whole motor....or have the know how to rig up the MSD crank trigger to make.....I dont think the fuel injection stuff will do you any good.
