Old 11-12-2006, 11:47 PM   #1
Flatty
How to make a 4x4 ride smoother?
I have a pretty messed up neck (2 bulging disks due to being a wrestling coach), and I will be buying one of these trucks here in the next few months... I used to have a lifted 99 cummins truck that was bouncy as all get up. My neck would kill me on LONg drives. I have always wanted a 67-72 4x4 truck, and now is my chance to get one. I build rockcrawlers for a hobby and need a tow rig. Why not get one that looks great also. My wife and I are buying a house and I will need another truck for a "work" truck. Soooo.... Enough with the background, I need some advice
What are my options as far as getting a better ride out of a 4x4? I plan on a long bed. I want to throw a 4" lift (or so) under it. I want to run a set of 35" tires under the truck. Whatcan I do to the suspension to make it a BIT smoother of a ride? I know the usual stuff like new bushings, new leaf springs,... I also plan on towing with this truck. For teh rear springs I was thinking about running the stockers with a shackle flip. I know I can get about 4" out ofthat. How about the front end?
Thanks for the advice
Dima
Flatty is offline   Reply With Quote
Old 11-12-2006, 11:52 PM   #2
1969k10stepside
Re: How to make a 4x4 ride smoother?
The shackle flip will make the rear tires move closer to the front of the bed and big enough tires will make it rub.I really cant help you with smoothening it out because a leaf springed solid axle truck will always ride rough.Here is a pic of my old 69 w/ a 6 inch lift w/ no shackle flip for reference.Its not pretty by any means but it gets the job done.let us know what you decide todo with it no matter what route you take.P.S. I need bigger tires
Attachment 224582
1969k10stepside is offline   Reply With Quote
Old 11-13-2006, 01:10 AM   #3
Flatty
Thanks for letting me know that the rear axle would move forward. In that case, I may end up redoing the mounts and move the axle back where it beloongs.
Keep teh advice coming.
DIma
Old 11-13-2006, 08:17 AM   #4
Zoomad75
K5Camper
Zoomad75's Avatar
The shackle flip I did on my K5 didn't move the axle forward. It did make the rear ride a hell of a lot smoother though. As far as the front springs go, spend the extra money and use Tough Country or BDS, of for more go with Alcans.
The lower spring rate will give a smoother ride.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 11-13-2006, 12:24 PM   #5
Flatty
I was thining about Alcan's for this truck. I will talk to them abuot what the right sprint rate should be.
Dima
Old 11-13-2006, 12:47 PM   #6
Musclerodz
BDS or Alcons for the springs, and if the axle is not centered, ORD zero rates are drilled to relocated the axle either 1" or 1 1/2". Don't forget about a good quality tire . Nitto Grappler tires are fairly smooth and quiet. Nice late model seats will help too.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 11-13-2006, 12:53 PM   #7
Flatty
Mike
I have 2 sets of BMW seats for the truck... I was actually thiking about getting a set of suspension seats for the truck. Maybe a set of PRP seats or some BEard racing seats...
Dima
Old 11-13-2006, 01:44 PM   #8
Mudder
Mudder's Avatar
Good shocks with the different settings like the Rancho 9000's.
Mudder is offline   Reply With Quote
Old 11-13-2006, 04:22 PM   #9
Crank
Crank's Avatar
I dont know much about making them ride smoother, but this is about the only thing I could think of. Put a hitch on it and you are good to go. Could also haul all of your buddies.
Crank is offline   Reply With Quote
Old 11-14-2006, 01:26 AM   #10
68shortfleet
I have installed several sets of the TUFF COUNTRY springs, and would not ever recommend them to anybody again. They are the roughest riding spring I have ever installed in a chevy truck. I have no experience with alcans, But never heard anything bad about them. Springs that i did like were the RANCHO'S. Good ride/affordable. Definently run an adjustable shock(rancho), I had bad luck with the pro comp adjustables.
Just my opinion
Jason
68shortfleet is offline   Reply With Quote
Old 11-14-2006, 11:29 AM   #11
Flatty
Just my opinion
Jason
I can't stand RANCHO springs. They are built like poop... I have been wheeling for about 15 years now, so building rockcrawlers has been my second job. I have run just about every spring imaginable, and stockers are usually the smoothest of them all. That is why I want to run the stockers in the back with a shackle flip. tHen I will probably run a set of ALCAN's in the front with adjustable shocks (Or bilsteins). The main part is to run a good quality seat. Either the M3 seats from the BMW are going in, or the Corbeaus.
DIma
Old 11-15-2006, 12:20 AM   #12
1tonswb
1tonswb's Avatar
Just my opinion
Jason
FINALLY!!! Someone who knows what there talking about!! For years I have watched people praise the tuff country springs when IMO they ride VERY harsh. Ive always had very good luck with the skyjacker softrides. They ride smooth and they are very flexy. They are spendy but you get what you pay for. As far as rear springs either run a softride or factory 1/2 ton springs. 3/4 ton springs ride wayyyyy stiff.
Ditto on the rancho 9000's. The pro comp mx6's are junk IMO. I cant count how many mx6's I have warrenty'd out over the years compared to 9000's.
1tonswb is offline   Reply With Quote
Old 11-14-2006, 07:43 PM   #13
cobinder
Everything is work in progress
cobinder's Avatar
With a shackle flip your axle only moves forward if you have springs with a lot of ach in them. The flatter the spring the less it moves. My 80 K20 moved about a 1/4" with a 4" shackle flip on stock springs.
Get good tires and spend $$ for good shocks (like Bilsteins)
Best ride I've found yet!
The seats would be the last place to dial in your comfy self (and the most $$)
good luck
cobinder is offline   Reply With Quote
Old 11-15-2006, 01:27 PM   #14
jamesjones
Freakin Awesome!
jamesjones's Avatar
Deaver Springs and whatever brand rezzy shock you prefer. It will float like a butterfly.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 11-17-2006, 01:59 AM   #15
skchevota
skchevota's Avatar
definitly use a custom spring like an alcan or deaver if you hav the $$$ if not use the skyjackers, I would also consider a longer spring, I run rear 52" springs in the front of mine, and stock superduty rear springs in the rear.
The longer the spring the beter the ride, I ren a set of stock superduty springs in the front of my 98 chevy with a SFA and it road like a caddy, and flexed reallll nice to. then of coarse rancho 9000s
skchevota is offline   Reply With Quote
Old 11-17-2006, 02:22 AM   #16
Russell
Professional Grade
Russell's Avatar
If you've got money to spend, and want a very nice ride, air bag your truck front and rear with 4 link suspensions setups on both axles, and get some good shocks.
If not, take your leaf springs apart, have them blasted, then coated with graphite empregnated paint, and re-assemble with new teflon strips between the leaves, and new bushings. Re-install using some good adjustable shocks. As mentioned above, you can do some hanger relocating and use longer springs up front, and out back to improve the ride as well.
Finally, use a set of aluminum wheels, the less un-sprung weight the better the ride
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 11-19-2006, 10:55 AM   #17
scotto0609
Junior Member
Watch the load range on the tires and inflation,just because it says max inflation xx doesnt need it needs to be there!
scotto0609 is offline   Reply With Quote
Old 11-19-2006, 11:16 AM   #18
72freak
Rottenwood Garage Member
72freak's Avatar
Yep.........thats what I was going to say.......lower your air pressure in your tires!!!!!
72freak is offline   Reply With Quote
Old 11-19-2006, 12:58 PM   #19
Mudder
Mudder's Avatar
I run around 20-25 lbs in the swampers on the highway.
Old 11-22-2006, 10:06 PM   #20
454_72_4X4
454_72_4X4's Avatar
I can tell you DEFINATELY DON'T use Rough Country springs.
I've been thinking about airbagging the front of my 72 for some time now. Any good ideas about fabricating or buying the links for a 4 link setup?
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 11-25-2006, 03:35 AM   #21
earl87gta
earl87gta's Avatar
here is a good post on a 4x4 with air bags
http://67-72chevytrucks.com/vboard/s...d.php?t=200909
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 11-25-2006, 04:17 AM   #22
89 crew
An idea no one mentioned here was an air ride seat. They are fully adjustable (if the right brand is bought) and if they can smooth out a 54k lb truck running 110lbs in the tires it and enough spring to carry that weight it should be able to take care of a 6k truck.
89 crew is offline   Reply With Quote
Old 11-26-2006, 02:45 AM   #23
454_72_4X4
454_72_4X4's Avatar
One problem I see with the air ride seat is headroom.
These old trucks don't have much room to begin with so there's just not enough room for the seat suspension to work without bashing your head against the roof.
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 11-26-2006, 11:25 AM   #24
rancid
rancid's Avatar
i would have to agree on the superduty srings. i had a 96 suburban that i did a solid axle on and ran 4" skyjacker springs on front with about a 4" drop from the frame and ran 40,s and did a shackle flip on the rear. but i moved my hangers back 2 inches so the tire wasnt so close after the flip, i ran a 5 inch rear spring and a 2 inch block. it may be hard to believe but it rode better than when it was stock. it ended up with about 12" lift.
rancid is offline   Reply With Quote
