Any interest in a detailed late model seat install??
I will be installing a late model tahoe/yukon 2nd row seat, and if there's any interest, I could shoot some detailed photo's
Here's one already installed
70 GMC shortbed fleetside with a 72 chevy costume |
Re: Any interest in a detailed late model seat install??
After doing a tune-up on the upholstery, I'll be installing this in my 72
70 GMC shortbed fleetside with a 72 chevy costume Last edited by 72dually; 11-13-2006 at 07:58 PM. |
wow thats pretty sweet... i was always thinking of using 98 style seats and the center console... id like to see some pics if you got em.. how low do they sit? i like to sit fairly low.
-1947 3100 -1968 C10 -1970 K20 |
and maybe more pics of thet whole truck as well... i like the color.
Junior Member
Good idea! Would love to see some pics!
1970 C-10 Fleet Side Gen IV 6.0 with 4L80E |
I just got these on Ebay ($20) and hope to install them in my 68. There are other threads that show the install but more is always good. These are 2nd row from 2000 burb, only problem that I have heard of is that they sit a little high, nothing a cuttoff wheel and welder cant fix. The one's that have integrated seat belts are nice but you need to reinforce the floor from the bottom or you will eject in a crash...
#7 | |
if they bolt into the stock holes then no biggy, seat belts are still going to be mounted in normal spot for now. If I decide to add shoulder harness then it will need reinforced. I probably will since it's an older truck and I am a big guy....
i'm interested, i would like to see pics with someone close to 6' seated in the truck with feet and leg room and stearing colume clearance they sure look nice but comfort and function are more important to me and don't want to buy some to find i don't like them
common sense isn't so common anymore |
laying low
![]() Join Date: Mar 2001
I agree Wibill. You can't just go down to your nearest truck dealer and try one on to see how you fit. Of all the thousands of pics I have viewed on these forums I can't remember ever seeing anyone sitting in the drivers seat with the door open. You know so you can see how close everything is with a much more padded seat installed. I also am considering that second row Burb seat for my 69 step. It sure is padded nice and the fold up bottom is good for a small bit of storage. A bonus.
72 Dually, go ahead and snap a couple if you would. I think we'd all like to see em. thanks. Boog.
I'm 6'3 so my pics won't help, I don't fit in anything!!!!
I am also looking into the tilt column or moving mine forward to gain room. I have a stick shift so it should be hard. |
Chief Honcho In Charge
I am interested. What did the seats cost you...the" late model tahoe/yukon 2nd row seat" you mentioned.
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
#13 | |
One thing to keep in mind is the 1999 and earlier 2nd row seats have the wide floor mounting. This seats out of a 2002 tahoe, but suburban is the same. If Im not mistaken the Yukon has the big headrests, which I dont care for. 2001-2007 have the same mounting, possibly the 2000 too, but I cant say for sure. Seeing how there's some interest, I'll make sure to take a bunch of photo's There will be some mods needed, but I've learned a few tricks on the height issue's, by playing around in the boneyards with other makes, and models
70 GMC shortbed fleetside with a 72 chevy costume Last edited by 72dually; 11-13-2006 at 10:19 PM. |
67-72 Addict!
Nice looking seats. I'd be interested in how narrow they are compared to a stock bench. I have seen a few that look to be about 3-4" narrower on each end than a stock bench.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#15 | |
Full power with heat out of a 2002 Chrysler 300, complimented by a center console from a 99 grand prix. Keep us informed, i'm always interested in the approach that different people take. ![]()
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
#16 |
67-72 Addict!
Wow!- they look nice also!
#17 |
msgross, i added a van tilt and pusshed it foward till it hits the cluster and with stock bench seat i still like it all the way up so its not right on my lap. it is a must to tip it up for ingress , egress and i'm only 5'9" and a buck 70 and have the newer smaller wheel, so i beleave any seat close to the factory bench height is just to tall but i don't want anything too low to loose visibality
