11-13-2006, 08:35 PM | #1 |
good driver shape cab f/s
here is a nice driver shape cab restore has been started .the cab corners have been replaced it needs driver outer rocker. floor and inner rockers and floor suports look good. floors have had miner work done on top inside cab it was not bad all the way threw. bare cab with out doors, brake booster,auto colum, floor shifter,$500.00 . if you need any of the other parts seen on cab in pic. i will make you a price with the parts you need. cab does have good ky paper work with it and radio has been cut but i will throw in a patch with it. respond here first if interested in it.[SOLD] Last edited by billsbowtie; 12-05-2006 at 06:50 PM. |
11-13-2006, 08:37 PM | #2 |
Re: good driver shape cab f/s
if you want the 72 lwb frame leaf spring 5 lug with cab add $100.00.
11-13-2006, 08:38 PM | #3 |
grille and rad.suport add $50.00.
11-13-2006, 08:38 PM | #4 |
11-13-2006, 08:39 PM | #5 |
cab around windshield was sanded and primmered.
11-13-2006, 08:39 PM | #6 |
11-13-2006, 08:40 PM | #7 |
11-13-2006, 08:40 PM | #8 |
11-13-2006, 08:40 PM | #9 |
11-13-2006, 08:40 PM | #10 |
11-13-2006, 08:41 PM | #11 |
11-13-2006, 08:41 PM | #12 |
11-13-2006, 08:41 PM | #13 |
11-13-2006, 08:43 PM | #14 |
11-13-2006, 08:43 PM | #15 |
11-13-2006, 08:44 PM | #16 |
11-13-2006, 08:44 PM | #17 |
11-13-2006, 08:45 PM | #18 |
11-13-2006, 08:45 PM | #19 |
11-13-2006, 08:45 PM | #20 |
11-13-2006, 08:46 PM | #21 |
11-13-2006, 08:47 PM | #22 |
11-13-2006, 09:39 PM | #23 |
Bill, is that frame straight from the cab back. I can't tell by the pix. No kick out? like what would mount a coil spring on a trailing arm rear suspension.
Thanks, Steve |
11-14-2006, 03:02 PM | #24 |
Qksilver, The frame on my 72 leaf does have the "kick out" just like the coil spring frame even though nothing mounts there.. In other words it's not straight like the 4x4 frame.
72 Cheyenne Super 80 Silverado Blazer 2wd |
11-14-2006, 12:07 PM | #25 |
steve frame is nice shape.
