11-16-2006, 06:15 PM | #1 |
Leaky weather stripping..........Fixes
When I repainted my K-20, I had to replace the weather stripping(Obviously ) today was the first time I had it out in the rain..........and although the doors are fitting the body nice, and are tight(From what I can see and I don't hear air when I go down the road), it drips some at the tops of the doors. How can I tighten this up without adjusting the doors and screwing up everything else(body lines, latch, etc)
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
11-16-2006, 07:06 PM | #2 |
Questionable
Re: Leaky weather stripping..........Fixes
*bump*
I just ripped all my trim out. I didn't realize the factory trim actually glued in place (I don't like that and wish there was another way!). Anyone have suggestions on how to best install factory replacement (what glue, process, etc.), how to locate and patch air leaks, and any info on trim OTHER than factory that can be used? I heard people using Astrovan and S10 trim in their trucks. Not sure how diff't the install is.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
11-16-2006, 07:33 PM | #3 |
ttt
shifty what year is it because the trucks that i'v taken trim off of is either popped in a hole or bolted on
(Only) Member of the CPNE Fan Club Aint that the truth 67 C-10 350 with 3-speed tranny and 308 gears swb step 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) Last edited by CPNEJR; 11-16-2006 at 07:34 PM. |
11-16-2006, 09:58 PM | #4 |
I make Models
Had the same problem with my 72......I ended up adjusting the door in slightly at the top and this seems to have cured the problem.....I have the painted on pinstripe down the side and the adjust did not even effect the way it lines up......good luck with it.....
11-17-2006, 01:08 AM | #5 |
Questionable
CPNEJR, it's a 68 stepside.
11-17-2006, 03:08 AM | #6 |
Out of the carpool lane.
I've currently got weatherstripping that I picked up at the junkyard from an early '90s fullsize Chevy truck.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
11-17-2006, 03:31 PM | #7 |
Questionable
Does it slip on, or glue on? What's it like while driving down the highway at a high rate of speed?
11-17-2006, 07:03 PM | #8 |
It just slips on and you'll have to cut about 2". It's a little thicker so you might encounter a little resistance closing your door, but it'll seal much nicer and no extra wind noise besides what's inherent in the truck.
11-18-2006, 01:10 AM | #9 |
Questionable
Good advice! Now, big questions is ... what year?
And who wants to buy the stock OEM-repro door seals I just bought from GMCPauls?
